Can't get the battery out!! Help
Old Dec 2, 2007 | 11:16 AM
zoutv's Avatar
2000SE. First time I ever had to take the battery out. The negative comes off fine. But the positive....what a B!tch. I have the clamp completely loose and ready to come off. But the 'bracket' or whatever it is...will not flex or move at all for me to slide the clamp off the positive terminal.
I have no idea what the exact name is, but to the left of the poitive clamp is another nut and washer. To the left of that is a fuse on top of the 'arm.' I started to just pry the 'arm' up a bit and to the left...but worried I'll break something.
What step am I missing?
Old Dec 2, 2007 | 12:24 PM
zoutv's Avatar
Anyone?
Old Dec 2, 2007 | 12:39 PM
redmaxpa007's Avatar
i SeE what you did therE
sounds like the positive is just stuck..
make sure the negative is not touching the anyhting conductive.. and get a screwdriver and pry the positive off...
Old Dec 2, 2007 | 12:45 PM
zoutv's Avatar
I will try this. But even if I get the terminal clamp free, so its not touching the positive terminal at all, It seems that I have to bend the terminal clamp up to get it over the head? Worried that I may damage the nonflexible 'arm' that attaches to the positive terminal.
Old Dec 2, 2007 | 01:10 PM
01_blue_max's Avatar
when one of the terminals is stuck, i usually tap it lightly w/ the ratchet to break it free.
Old Dec 2, 2007 | 01:18 PM
jasonmax's Avatar
pour some hot water on it
Old Dec 2, 2007 | 01:26 PM
00SEMAX19's Avatar
You can unbolt the complete terminal from the fuse housing. Also the possitive terminal fhould lift at least 2 inches above the battery alowing you to remove from battery without bending anything unless somebody put a battery that is to big in.
Old Dec 2, 2007 | 01:31 PM
DasYears
just tap the terminal side to side until it rotates, then lift
Old Dec 3, 2007 | 10:13 AM
gotcha640's Avatar
When I bought my battery at Autozone, they told me there's two sizes that are listed for the car (00 GLE). One's taller, ones wider. They only had the taller one. It's a little tight, but it still hooks up.
Old Dec 3, 2007 | 10:33 AM
vq35's Avatar
our battery recommended size is max-24fn
Old Dec 3, 2007 | 10:59 AM
Merlyn's Avatar
And... I'm out
All else fails either hit it with a hammer or take the motor out... my 2 cents
Old Dec 3, 2007 | 11:57 AM
Professor's Avatar
channel locks are your best friend, i install about 30 batteries a week, just use them and wiggle back and forth.
Old Dec 4, 2007 | 11:19 PM
spdfreak's Avatar
Where do you work? I want to know where never to bring my car.
Just kidding.
Old Dec 5, 2007 | 01:46 AM
AceofSpds's Avatar
wat
Just kidding.
Advance auto parts for ya man!
I do it too lol
Old Dec 5, 2007 | 12:54 PM
spdfreak's Avatar
I do it too lol
Good thing I'm not your boss.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
