Messed up my headlights trying to clean them need help
They were a little bit foggy so i took a 1500g wet sand paper and sanded it and now its worse than before can barely see the reflector. Tried buffing it with plastic x and it didn't do S#it, then i used aluminum polish it cleared it a bit but still its very foggy and need advise what should i do? but on the pllus side there were some chiped out parts now there gone
Here you go: http://forums.maxima.org/showthread.php?t=332187
re-do it the right way:
http://forums.maxima.org/showthread....91#post3743491
hopefully you haven't taken too much of the plastic lens off...be gentle.
you need to go all the way to 2000 grit. go to autozone. they have it. then use the plastic x after. let the plastic x sit on the lens after you spread it around (kinda like wax). then push hard while buffing. it'll be all good after that.
AaronL
Nov 15, 2020 11:52 AM
sdotcarter
Sep 2, 2015 09:53 PM
