Rear View Mirror Jiggle??
Old Dec 24, 2007 | 02:32 PM
nk2k2's Avatar
So i was looking at my rear view mirror that other day, and it moves. Okay now i know that sounds dumb but i mean it moves on the stem. It feels loose.
Picture this: you know how you put your whole hand to adjust it, well now with your hand on the rvm, you can feel it jiggle in your hand. its almost like you have your hand on it and your trying to rotate it around.
im sorry if that sounds convoluted.
im trying to figure out if there is a way to dismantle it to possibly tighten it.
im assuming the base from the BOSE over the years has something to do with it because when i listen to songs with base, the rvm vibrates.
So anyone have an idea how to take apart one of these things?
Old Dec 24, 2007 | 06:40 PM
ZIPPIN's Avatar
Mauja He Mauja
I seriously doubt the bose subwoofer had anything to do with it.
Check this:
http://forums.maxima.org/showthread....ar+view+mirror
Old Dec 24, 2007 | 06:41 PM
Professor's Avatar
eh hehe mine moves so bad from the bass the window is cracked around the mirror mount on the other hand, i dont have the oem bose
Old Dec 25, 2007 | 10:09 AM
nk2k2's Avatar
zippen i like how you posted my old thread lol. yeah that was from my old max. is this a common issue with the 5.5 max? i mean this is my 2nd 5.5 and ive had the same problem.
Old Dec 25, 2007 | 10:25 AM
jasonmax's Avatar
I have to say a little bit loose and play, but not that serious.
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Had the same problem on my (5th Gen) I-30. There's a little set screw underneath or on the back side of the mirror that you can use to tighten it up. The mirror mounts like a bathroom towel rack does...there's a metal mounting plate that is glued to the windshield, then the mirror mounts to the plate. It's a very easy fix.
Old Dec 25, 2007 | 11:43 AM
nk2k2's Avatar
Talkinghorse: are you talking about the torx that is on the mounting thing on the windshield?
Old Dec 25, 2007 | 05:32 PM
I did mine about a year ago. There's a little set screw on the bottom of the mirror. If the set screw is tight, you'll have to remove the screw and remove the mirror. When you remove the mirror, you'll see a bracket which screws to the mounting plate. The mirror screws to the bracket, and the bracket is screwed to the mounting plate. The mounting plate is glued to the windshield. The problem with mine was that the bracket had loosened up from the mounting plate causing the whole mirror to be loose. It's easy to fix...just a pain.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
flu2000
Sep 8, 2015 02:23 PM
