are my rear calipers cashed?
Old Dec 25, 2007 | 12:46 PM
Armon's Avatar
Last time I got some brake work done the guy told me that both rear calipers were "really tough to open." I didn't really think much of it since he said both the rears were the same.
A few months later I started to hear a rubbing sound from one of the rear calipers. It was a very deep sound that would only happen at 5-10 mph while I was turning or going up a hill.
Anyway, now I've got them off myself. I haven't gotten to the left side yet, but the right rear caliper will not go back on. I suppose I could hammer it into place, but I know it's supposed to be pretty easy.
Is it time to call DaveB for some replacement parts?
Old Dec 25, 2007 | 01:12 PM
miksen's Avatar
FU, FU, FU, You're Cool..
you used the correct tool to open them right?...the rears require a specific tool to back of the piston
Old Dec 25, 2007 | 01:13 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
You need to get the brake tool.. go to autozone and rent it. The rear caliper is a screw.. so no hammer need it. Use some WD 40 and or any other lubricant to clean around the seal.. if the seal is broken just add as much bubricant as you can.... and try to get a rear caliper kit to fix it yourself. This is the tool you need, website if you need to read about it.
http://www.algrovetoolsupply.com/cgi...?item=LIS25000
Old Dec 25, 2007 | 01:40 PM
Tippy Toes's Avatar
Good information thanks lontar. Merry christmas all
Old Dec 25, 2007 | 02:12 PM
Armon's Avatar
thanks lontar
Old Dec 26, 2007 | 05:29 AM
djfrestyl's Avatar
Suspension Yoda
My caliper piston was fine but the pins were seized. Took a vice and a blowtorch to get them out of the torque member. Might want to regrease those...
Old Dec 26, 2007 | 09:42 AM
Armon's Avatar
okay well neither auto parts store has that tool. One offered to loan me a "master tool kit" for the low price of $99. No thanks.
There's gotta be some way to get it to back out without the tool. I'm not putting new pads on, I just need to get it <5mm wider so that it will clear that little protrusion/nub on the back of the brake pad.
Old Dec 26, 2007 | 09:45 AM
miksen's Avatar
I found mine at a local speed shop paid $5 too much for it but they had it in stock...I can not think of a way to do it without the tool...the piston is threaded
Old Dec 26, 2007 | 10:38 AM
huffdaddy2008's Avatar
i like how you said cashed like your brakes are a bowl or something
gl w/ de brakes tho
Old Dec 26, 2007 | 02:28 PM
Lontar1's Avatar
Do you have an Autozone close? They rent tools.... "Free of charge"....
Old Dec 26, 2007 | 07:08 PM
Armon's Avatar
I ended up buying a little cube shaped universal tool that fits on a socket wrench. It worked, and only cost like 5 bucks.
Thanks for the help
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
beerman1378
Sep 8, 2015 02:19 PM
