Right Fog Light will not light up
Old Jan 5, 2008 | 10:51 AM
WeBrake4Nobody's Avatar
Can anyone help me out here? I checked everything that needs to be checked out here....The fuses are ok...the wiring is ok...the bulb is fine (have a brand new spare as well). What else could it be that it won't fire up? Any assistance anyone can offer would be greatly appreciated here.
Old Jan 5, 2008 | 10:59 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
if you already did all that... remove the other side and test the whole assembly to see if there is something wrong with your fog light.. or if you have a tester check with that first
Old Jan 5, 2008 | 01:40 PM
Deckdout2's Avatar
Play with my balls
Is the switch turned on?
Old Jan 5, 2008 | 01:55 PM
nismowolfe's Avatar
I think the only thing you didnt mention is the relay. It would be weird if one light would work and not the other if it was the relay.
Old Jan 5, 2008 | 02:26 PM
So I'm on the level of beginner/intermediate in terms of knowledge of electrics with my car. Where is the relay? I was originally having problems with the left foglight but now that's never an issue. Just the right side.
Old Jan 5, 2008 | 02:49 PM
trigger005's Avatar
have you done the foglight rewire mod to allow the foglights to stay on by themselves?
Old Jan 5, 2008 | 02:55 PM
nismowolfe's Avatar
The relay is under the dash somewhere I believe on the drivers side by the fuse box dont quote me on that if you look under the how toos for fog light mod it tells you where its at I just dont remember and I havent done the mod. I dont know how to check the relay to see if its bad but you could just replace it usually they are not that exspensive and see if that solves the problem.
Old Jan 7, 2008 | 06:15 AM
To trigger005's comment. Yes I did do the foglight rewire that allows the foglights to be on by themselves. How would that play a role in this problem I'm having?
Old Sep 8, 2008 | 11:42 AM
pyroz's Avatar
bump, how would the rewire trigger this problem?
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
