start up outa wack!
Old Jan 6, 2008 | 04:35 PM
dAAmax's Avatar
start up outa wack!
hey watsup guys...i have a stillen hi-flow intake and i was wondering why the start up has been a little wierd lately (im guessing its the cold weather), but when when i turn the key it sounds like the intake is like choking a little and it delays a couple of times and then finally starts up but it sounds like its really struggling to get it going...any suggestions??? thanks guys
Old Jan 6, 2008 | 04:45 PM
SoonerFan's Avatar
Cletus
MAF?
when i had the stillen, it kept popping off the throttle body which means the MAF is getting a bad flow
Old Jan 6, 2008 | 07:51 PM
dAAmax's Avatar
oooo...any suggestions on what to do?
Old Jan 6, 2008 | 08:36 PM
SoonerFan's Avatar
Cletus
make sure everything is connected correctly
Old Jan 6, 2008 | 08:41 PM
crazy97's Avatar
Have you had any transmission work lately?
Old Jan 6, 2008 | 08:57 PM
irish44j's Avatar
retired moderator
generally, cars take a bit longer to start when the weather turns cold. That's just the way it is
Old Jan 7, 2008 | 12:47 PM
dAAmax's Avatar
nahh man
Old Apr 6, 2008 | 07:20 AM
NisTech's Avatar
if it starts up then Rpms drop to like 2-300 rpm then goes right away back up you need an idle air volume relearn performed to relearn how much air is going through at idle. Also it will make the car back to where it was in terms of idle and throttle response.
This is if you're an 02 Max or newer especially
Old Apr 6, 2008 | 08:16 AM
Professor's Avatar
Originally Posted by dc_maxima
REPLACE UR GROUND WIRE!!! BOLT TO TRANNY MOUNT ITS FIX ALL MY RLECTRICAL PROBLEMS!!!!!!!!!!
Old Apr 6, 2008 | 01:02 PM
choiiiiiiiiiii's Avatar
he's been doing that lately. if you find them, they're all the same stupid ground wire post.
trying to get that fifteen.
Old Apr 6, 2008 | 03:58 PM
Scottwax's Avatar
That's Mr. Detail to you
A ban would stop him at 11....
Old Apr 6, 2008 | 04:47 PM
hah indeed it would.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
