bypass valve for cold air intake
Old Oct 26, 2001 | 01:37 PM
a33's Avatar
a33
hi
i have the cattman cold air intake and i want to know if there is a bypass valve for it...
i live in toronto canada and we have pretty terrible weather conditions in the winter, do i actually need one???
is the cattman cold air intkae alone very unsafe???
Old Oct 26, 2001 | 01:51 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
It's safe without the bypass valve. I believe someone posted a recall by AEM on the valves a while back.
Just don't drive in flooded areas.
Old Oct 26, 2001 | 02:09 PM
Rob'sAE's Avatar
You're Faster, I'm Better
That is not even really true, at least in my case. I have an OSCAI intake and it sucks air from underneath the splash guard. To make a long story short I had to drive thru one of Houston's downpours and ended up going thru at least 6 inches of water to get my family out. No water inhilation. You do have a true aftermarket CAI, but as long as the water does dot make it up to the airfilter (the fender right?)
Old Oct 26, 2001 | 04:39 PM
UMD_MaxSE's Avatar
Got Bent?
the recall on the AEM bypass valves is fixed I think.... you could stick one on the PR CAI tubing....
Old Oct 26, 2001 | 05:40 PM
mtrai760's Avatar
'Trynna' is not a word
The recall was only on certain part#'s, because the valves on the bypass were coming off and lodging in the throttle body, sticking the throttle wide open. It has been fixed and pertained to certain part numbers that were made...
Old Oct 26, 2001 | 09:38 PM
Jeff2k1GLE's Avatar
where exactly does it go on the PR CAI? i just got mine in the mail today
Old Oct 27, 2001 | 12:28 AM
Y2KevSE's Avatar
Maybe you can put it before the MAF if possible... otherwise, you might have to chop the CAI piping.
Thanks for the update guys.
Old Oct 27, 2001 | 02:48 AM
BigDogJonx's Avatar
I dont think the Bypass valve is gonna help, I saw somewhere on the net that it showed a cold air intake pipe with about 1 foot of water up the pipe and still was not getting near the engine. I think this was at full throttle and EXCESSIVE water, I believe they actually put it near a bucket of water.
That was to prove that it is not needed.
Dixit
Old Oct 27, 2001 | 07:12 AM
Jeff2k1GLE's Avatar
do you think it will still serve it's purpose if it's right before the maf??
http://www.aempower.com/magart.htm
Old Oct 27, 2001 | 07:26 AM
UMD_MaxSE's Avatar
Got Bent?
it should..... there is plenty of air around there also for it to suck in.
Old Oct 27, 2001 | 08:02 AM
ohboiya's Avatar
Re: bypass valve for cold air intake
why don't u just wait till spring? or .. r u going 2 store your car?
Originally posted by chengkumcheung
hi
cruce91
Sep 20, 2015 10:23 AM
tardrex
Sep 11, 2015 07:35 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
