No power after 4k rpm
2000 5 speed maxima, my car feels as if it's losing power after 4k rpm it feels as if the power band is just flattening out.....could this be a knock sensor issue?? the car has no codes(or ghost codes). The car runs perfectly otherwise. Any input, fuel, spark, timing being retarded??
Thanks in advance
Thanks in advance
Anything else?
If it's your MAF, simple... If it gets worse, especially hesitation early in the powerband, then probably alternator. Easier to feel in an AUTO because the transmission will knock and the shift points will be off. Battery and brake light stay off?
playboi yes is does cause poor throttle respose.... mine would cut out at 35oo rpms mostly and would take forever to get to 4000....rough shifts and banging into gears was also something i had...
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
watch your tempature should get hot and possible overheat if its clogged cat.
