cattman header then CEL
Old Jan 14, 2008 | 08:48 AM
qnpark8282's Avatar
Over the weekend I install the cattman headers and th o2 simulators. So i drive around for about 80 miles over course of 2 days. Then I get a CEL. So I check with the consult. Im getting a code P0057 and P0058. High voltage on o2 sensor bank 1 sensor 2 and bank 2 sensor 2. I thought I leave the heater signal untouched on the o2 sensors and then just zip tie the sensors to the side. Now im getting a code?? Am I doing something wroung with the simulator. I just tapped the pos, neg and signal and left the heater wire alone on both of the o2 sensors.
Old Jan 14, 2008 | 10:06 AM
OOmaxSE's Avatar
You did it right, leave the heater wires untouched. Now, usually codes for heaters go on - SES because the sensors go bad. You can either buy resistors to get rid of these codes (o2simulator.com) or buy two new sensors. Although it is strange that they came on right as you put the header on. Try unplugging the battery overnight?
Old Jan 14, 2008 | 01:43 PM
huffdaddy2008's Avatar
This happened to me too , just a little bit more time passed than you. Those codes (high voltage, slow responce and no activity) popped up a few times on but have gone away since.
Heres some reading: http://forums.maxima.org/showthread.php?t=326212
Old Jan 15, 2008 | 05:40 AM
qnpark8282's Avatar
well i cleared the codes yesterday, imma hope it dont come back.
Old Jan 15, 2008 | 10:37 AM
miksen's Avatar
FU, FU, FU, You're Cool..
i need a dual circuit sim myself...where and what did you buy?
Old Jan 16, 2008 | 07:41 AM
Puppetmaster's Avatar
www.o2sim.com
Old Jan 16, 2008 | 07:43 AM
That's what I'd do for now. I'm assuming you've re-checked all your wiring and connections? How and where did you connect the sim to the harness?
Old Jan 16, 2008 | 11:19 AM
qnpark8282's Avatar
I tapped the main hardness. postive and the signal(white wire) and i grounded the neg to the engine. When i get a time i'll take some pics.
Old Jan 16, 2008 | 12:01 PM
Yeah, pics would be good, thanks.
Did you install before or after the plastic connectors? If you did it before, on the ECU harness itself, you can check my thread too:
http://forums.maxima.org/showthread.php?t=350787
Old Jan 17, 2008 | 06:28 AM
qnpark8282's Avatar
well here are the pics.
Old Jan 18, 2008 | 04:44 AM
qnpark8282's Avatar
well after 200 miles, nothing yet.
jmlee44
Oct 2, 2022 02:13 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
JoshG
51
Sep 21, 2015 10:41 PM
Chaka
Sep 17, 2015 09:53 AM
