Bad CV Joint?
Old Feb 4, 2008 | 08:47 AM
Vadim's Avatar
Bad CV Joint?
After searching and doing some research, I believe I have a bad CV joint. First of all, there is always a clunking noise when accelerating or decelerating. Second, yesterday coming back home from a long trip, I noticed that there is a very noticeable vibration when driving at speeds over 60 mph and slightly turning left (following the curves on a highway). It's fine when driving straight or slightly turning right. However, there seems to be no cliking when making sharp turns at low speeds. I checked the bearings about a week ago and there was no play either. Did anyone have a similar problem?
Old Feb 4, 2008 | 09:26 AM
BLACKKILA.GTR's Avatar
yeah i have the same problem lol
Old Feb 4, 2008 | 10:40 AM
Vadim's Avatar
So, did you replace the axle?
Old Feb 4, 2008 | 12:21 PM
djcallao's Avatar
If you replace them, obviously replace them with raxles. I did mine about 4 months ago and they are great.
Old Feb 4, 2008 | 07:12 PM
Vadim's Avatar
I think I was wrong again. I jacked up the car, checked the right wheel and there was play again!!! I re-tightened the axle and it seems fine now. I'll have to find a big torque wrench and make sure to tighten it to spec this time.
Old Feb 4, 2008 | 07:19 PM
L.M.L.
locktite it!
Old Feb 4, 2008 | 07:23 PM
Vadim's Avatar
Originally Posted by L.M.L.
locktite it!
I will! should 250lbs of torque be enough?
Old Feb 4, 2008 | 08:18 PM
nsnrider's Avatar
there should also be a lock pin on these things.
Old Feb 5, 2008 | 09:21 AM
Vadim's Avatar
Cotter pin only prevents the nut from coming off all the way. there is still a gap between the pin and the nut.
Old Feb 5, 2008 | 09:30 AM
SuperStasiu's Avatar
I was gonna say the same thing, the same thing happened to me my nut came loose and ****ed up my bearing and hub
Old Feb 5, 2008 | 10:54 AM
Double0GLE's Avatar
I have the a similar problem, where would this nut be exactly?
Old Feb 5, 2008 | 11:32 AM
Vadim's Avatar
take of your front wheels, it's the one on the center with a big pin in front of it.
Old Feb 6, 2008 | 10:57 AM
Vadim's Avatar
Does anyone know if the transverse link replacement involves taking off the axle nut? If that so, I wonder if they never tighten them back to spec.
Old Feb 6, 2008 | 11:03 AM
Vadim's Avatar
nevermind, i checked with the dealer and they said it doesn't.
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
