Exhaust question
Old Feb 11, 2008 | 10:55 AM
WxAxGxS's Avatar
Exhaust question
I'm not an expert in cars whatsoever, so I'm hoping someone can fill me in on this... I've got a stock '02 maxima (64k miles, 350z clutch/fidanza flywheel combo, but everything else is stock) and I noticed this morning in the cold weather (could see the exhaust as I let my car warm up) that the right pipe coming out of my muffler has ~4times as much exhaust coming out of it as the left pipe. I had always assumed that the dual pipes were aesthetic and actually connected to the same exhaust, however when I covered up the right pipe with my foot, it was obvious that no more came out of the left and it was all being forced out around my foot.
So in short... If there is ~4 times more exhaust coming out of the right pipe (or 1/4 the exhaust out of the left.. which sould seem to really be the cae) what is going on? Should I bring it in or is this typical?
Thanks!
Old Feb 11, 2008 | 11:04 AM
jasonmax's Avatar
normal
watch this video
http://www.youtube.com/watch?v=590SCUUrxvM
Old Feb 11, 2008 | 11:30 AM
WxAxGxS's Avatar
Interesting.... Any reason for this?
Old Feb 11, 2008 | 11:33 AM
L.M.L.
never had an idea it would look like that... should check out mine.
Old Feb 11, 2008 | 11:47 AM
Puppetmaster's Avatar
Apparently, the muffler is valved; exhaust gases exit through one tip until a certain RPM and then the valve is pushed open at higher RPMs and the exhaust will exit through both.
EDIT - you can see that in the vid when the guy revs the gases exit both sides and at idle it is only one side.
Old Feb 11, 2008 | 12:35 PM
jkayca's Avatar
What's the point of the valve? Would you have better flow if it were "stuck" open all the time?
Old Feb 11, 2008 | 01:06 PM
MintVQ35's Avatar
I think the valve may be for decibel purposes, to keep the DB's down anything under WOT maybe.
Old Feb 11, 2008 | 01:29 PM
NmexMAX's Avatar
dot dot dot ...
An equal-length tuned exhaust with a variable capacity muffler derived from the one on the high performance Nissan Skyline GT-R reduces exhaust system backpressure, adds power and gives Maxima a quiet, yet throaty, sound.
http://www.nissanhelp.com/Models/200...escription.htm
Old Feb 11, 2008 | 01:49 PM
jasonmax's Avatar
It's for back presure, I don't know what it is called in English.
When the intake and exhaust valves open at the same time, mixed air goes in to the cylinders. But if the exhaust is flowing too much air out of it, mixed air will be sucked out of the cylinder, then you lost torgue at low revs. So when the rev is low, exhaust let less air goes out to keep more torque.
On the other hand, better flow means less resistence at high revs.
I read this from other website, but I'm not sure..
Old Feb 12, 2008 | 06:55 AM
jkayca's Avatar
Thanks for the info. That was quite informative.
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
