Strange 6th gear problem
Old Feb 15, 2008 | 02:49 PM
Lethal's Avatar
I was coming home from work today and as I was going to shift into 6th it felt like it didn't want to go in. I pulled a little harder and it moved a bit, then I pulled pretty hard and it went into gear. It didn't grind, it was as if it was rubbing against something going into 6th. All the other gears 1-5 and reverse are fine. 6th gear feels like there is something rubbing on it as it goes into gear and you have to pull it pretty hard to go in. I cant figure out what this might be. Any ideas?
Old Feb 16, 2008 | 10:38 AM
MaximaGT-R's Avatar
I'm a Happy Man!
do you have an sts? if so check it out make sure it not hitting anything.
Old Feb 16, 2008 | 05:24 PM
Lethal's Avatar
Hey thanks for the reply, I don't have a sts. But I think it may be the cable binding up someplace. I disconnected the shift linkage in the cabin and the stick moves around freely so its not there. The only places left for the hang up are in the tranny itself and the cable. I am going to disconnect the linkage at the transmission. If it moves freely the problem has to be in the transmission.
Old Feb 18, 2008 | 07:12 AM
knight_yyz's Avatar
Toolie
there are no cables, 6 speed uses shift rods
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
slowlifer
Sep 8, 2015 05:53 AM
