When should I change the transmission fluid?
Old Feb 23, 2008 | 04:43 PM
ryanpa's Avatar
Hi all,
I purchased my Maxima about one year ago and I am starting to feel the transmission is not very smooth when changing from high to low gear. So I am just wondering when should I change the fluid? I did take out the transmission dip thing to check the fluid and it is on the normal level. But I have one question, the color of the fluid is very light purple, is this the color suppose to be? Because I remember on my old Maxima(93), the color of the fluid is dark purple(close to black). So which color is suppose to be for the fluid? I checked with my local car repair shop for changing the transmission fluid is $90. Is this price decent? Should I also change the transmission filter as well?
thanks a lot!!
Ryan
Old Feb 23, 2008 | 05:37 PM
Scottwax's Avatar
That's Mr. Detail to you
The fluid should be red and not have a burnt smell.
You can do a drain and fill pretty quickly. 19mm bolt, let the old ATF drain (I get around 4 quarts out each time), then refill with new ATF. I believe Nissan does not recommend having the transmission power flushed, so either drain and fill, or drain, pull the pan, clean the screen and magnets, install a new gasket and the pan and refill.
Old Feb 23, 2008 | 06:30 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
follow my writeup if up to the challenge
Old Feb 23, 2008 | 07:01 PM
Jess's Avatar
SHIFT_In2D
Yep it should be red, not purple. Depending on the mileage...say a high mileage car it would be recommended that you do a drain and refill. A flush may move around large particles causing transmission failure later down the road. (As I've read here on .org)
I just did a tranny flush at 49k miles and my fluid was brown colored. After flushing the shifting became smoother, and felt like there was more power.
Good luck!
Old Feb 23, 2008 | 09:30 PM
ryanpa's Avatar
Good luck!
Thanks for your information! I think I would just do the drain and refill. I would like to ask you how about the transmission filter? do i have to change it as well? Thanks!
Old Feb 24, 2008 | 02:36 AM
Lontar1's Avatar
it is not a filter
Old Feb 24, 2008 | 03:44 AM
meccanoble's Avatar
Sports Button FTW
I heard every 60k miles. I'm actually getting ready for my second flush....
Old Feb 24, 2008 | 06:27 AM
nsnrider's Avatar
I change the tranny at every 60k interval. Drain, drop the pan, clean the magnets, clean the screen, re-install pan with new gasket, fill ATF. Run tranny on lift for a few minutes through all gears, drain and refill with ATF.
You can skip on the re-drain and refill if you so choose, it just helps get rid off most of the old ATF.
Old Feb 24, 2008 | 01:41 PM
NmexMAX's Avatar
dot dot dot ...
I do as Scottwax does every 15k.
Old Feb 24, 2008 | 03:01 PM
L.M.L.
I have a leaking transmission, so I don't have to change the fluid
Old Feb 24, 2008 | 08:49 PM
95 Maxnout's Avatar
Fluid should be reddish in color.I'd def change it if it looks brownish or darker.
Old Feb 25, 2008 | 02:15 PM
BlackMaxima01's Avatar
I change it every 60K. I just did one a couple weeks ago with some Redline.
Old Feb 25, 2008 | 02:29 PM
cefiro80's Avatar
I change every 30K but I am a little **** about changing fluids. +1 for not flushing the system drain it and your car will be happier. Flushing puts more strain on the systems because some flushes requires you to pressurize a system and components might not be built for the pressure causing wear.
Old Feb 25, 2008 | 06:19 PM
maxximaa's Avatar
i feel bad for not having my tranny fluid changed, but im doing it for sure this summer
and probably getting it from the dealer, not labour tho
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
