Weird power/fuse issues
Old Feb 24, 2008 | 09:20 PM
OgreDave's Avatar
Friend needs help w/his 5th gen:
I just changed my stock HU to an aftermarket one
Now if I don’t start the car in longer than 24 hours, both the trip a and b are reset to 0.
Is this normal?
Secondly, my ac/temperature/ac mode are not lit anymore, which fuse should I look for?
Thanks in advance.
Old Feb 24, 2008 | 09:40 PM
pmohr's Avatar
No more Maximas...
While you're down there, just look through all of the fuses...
Is the gauge cluster completely losing power, or are the only symptoms his trips being reset?
Old Feb 24, 2008 | 09:49 PM
dual700's Avatar
Hi, thanks for responding.
The trip a and b are reset if I don't use the car for a while.
I did look at the fuse at least half a dozen to no avail (for the ac/temp/ac mode, below the stock hu)
Thanks again!
Old Feb 25, 2008 | 09:36 AM
L.M.L.
Thanks again!
afaik, there is only 2 ways to zero the trip a/b - you either hit the button or disable the power to the cluster. so, most likely you loose power to the cluster. keep looking for the fuse/wire.
Old Feb 25, 2008 | 10:35 PM
dual700's Avatar
Thanks guys, I'll keep on looking
AaronL
Nov 15, 2020 11:52 AM
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
bennuss
Sep 11, 2015 05:55 AM
pktaske
Sep 4, 2015 08:40 AM
