failed inspection with p0135 code/check engine light?
Old Mar 11, 2008 | 05:25 PM
albundy's Avatar
Now I have seen my check engine light come on after i get gas and the attendant doesnt screw the cap tight enough..and goes off a few days to a week later, but i also failed for p0135 which apparently is front o2 sensor(in pre-cat) do the 2 coincide with each other? if not how come the check engine light goes off after tightening the cap and waiting a few days? is that o2 senso easy to change if needed? thanks in advance..Nick
Old Mar 11, 2008 | 05:42 PM
SoonerFan's Avatar
Cletus
of course you will fail inspection with an emissions problems such as a bad O-2 sensor. replace it and then go back.
they are completely unrelated. just because the light goes of doesnt mean that the problem is gone. the code is still stored until you fix the problem.
Old Mar 11, 2008 | 06:13 PM
albundy's Avatar
if i fix the o2 sensor wont i have to reset the sel?
Old Mar 11, 2008 | 06:19 PM
SoonerFan's Avatar
Cletus
it will go away when it realizes that the problem is fixed. may take a couple days.
Old Mar 11, 2008 | 06:24 PM
Drockb418's Avatar
replace it and disconnect ur battery and u should be good to go
Old Mar 11, 2008 | 06:57 PM
albundy's Avatar
i have looked at the diagram off the tsb sites and am confused being there are 2 bank 1 front o2 sensors? one is in the pre cat? and the other is by manifold? can anyone explain where it is i am looking?
Old Mar 11, 2008 | 07:49 PM
IHAVEA2KMAXIMA's Avatar
Are you cali spec or fed?
http://forums.maxima.org/showpost.ph...&postcount=108
Old Mar 12, 2008 | 03:02 AM
albundy's Avatar
Originally Posted by IHAVEA2KMAXIMA
im gonna have to take a guess and say fed, so i am assuming the one with the black harness?
Old Mar 12, 2008 | 08:36 AM
SoonerFan's Avatar
Cletus
there are two O2 sensors before precats...front bank and rear bank.
Old Mar 12, 2008 | 08:39 AM
SoonerFan's Avatar
Cletus
i looked at the code sticky for you
P0135 - Front O2 Sensor Heater (Bank 1)
so yes, its the black one
Old Mar 12, 2008 | 09:54 AM
ReauDog's Avatar
I changed my o2 sensor about 3 weeks ago using the TSB. it takes only about 15 mins, its just a direct swap. as soon as i turned the car on my SES light turned off. i didn't even have to disconnect the battery.
Old Mar 12, 2008 | 02:38 PM
albundy's Avatar
i just looked at the one that prob needs replacing..unless i get a 5 year old to roll under there and worm his hands through everything i cant do it with out a lift, im calling around to friends who know mechanics
Old Mar 12, 2008 | 08:27 PM
Just get a ramp and rent the tools for free at your local AutoZone.
Old Mar 13, 2008 | 05:46 AM
ReauDog's Avatar
just jack it up and lay down...
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
