"Weathered" exterior trim
Old Mar 15, 2008 | 02:21 PM
maxspeedse02's Avatar
Thinks he is fast
I live in FL and my car has been parked outside for most of it's life so the black plastic trim on the exterior of my max has really gotten dull and dried out. I wanted to know what other max owners have done to fix this issue. I am considering replacing this stuff (if it is affordable) or perhaps sanding priming and repainting it all. I do not have any experience doing this and the black out window trim links in the stickies no longer work (even replacing showthread w/oldthread). The pieces I am referring to are the window trim top & bottom, plastic on the side mirrors, b pillar trim (I know this can be peeled off), the pillar that seperates the windows in the rear doors (this is the worst and it's doesn't appear to be the same material as the rest), and the trim around the front windshield. No matter what I decide to do, I will most likely need to remove these carefully and would like to know the best way to do this. Also feel free to name any particular products, brands or vendors you've used in this process. Thanks.
Old Mar 15, 2008 | 02:37 PM
SoonerFan's Avatar
Cletus
i have always used armor-all on mine to protect it...still looks new. if you do it, it would probably bring the color back out.
Old Mar 15, 2008 | 03:03 PM
DrunkieTheBear's Avatar
Turbo'd Saab
mothers has a product called back to black as well and it helps
Old Mar 15, 2008 | 05:02 PM
slickrick's Avatar
Ryan I used that back to black and it worked for about a month...now it looks like it did before I used it...very faded. I just leave it alone and don't worry about it.
Old Mar 15, 2008 | 05:07 PM
Thinks he is fast
I've tried using 303's protectant, mulitple applications, which really helped the cowl but these other items need more than that.
Old Mar 15, 2008 | 08:52 PM
Arek's Avatar
try this
http://www.autogeek.net/black-wow-trim-restorer.html
REDinLV
Aug 15, 2024 12:30 AM
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
