Glove Box issue
Old Mar 22, 2008 | 02:24 PM
00MaximaGXE's Avatar
Glove Box issue
I Put some things away in the glove box Navi, and a few cds Locked it now I cant open it with the key any help on getting this thing open? I have my Registration and Insurance stuff Inside If I get pulled over Im screwed
Old Mar 22, 2008 | 02:42 PM
SoonerFan's Avatar
Cletus
why would you lock it?
so the exact key that you used to lock it, won open it?
Old Mar 22, 2008 | 02:46 PM
Yes and I was in a bad part of Boston didn't want stuff stolen..
Old Mar 22, 2008 | 03:00 PM
trigger005's Avatar
locksmith can pick that thing open in 2 secs flat
goin 2 cost u $100 or so that way
Old Mar 22, 2008 | 03:03 PM
I was hoping there was a trick or something or if this happened to anyone else here
Old Mar 22, 2008 | 03:17 PM
SoonerFan's Avatar
Cletus
if there was a trick then the lock would be pretty pointless. it is designed to be secure.
Old Mar 22, 2008 | 03:36 PM
Yeah a trick with the key not without, Like push up while turning, a missing step I'm not doing. It also seem as the key isnt going in all the way
Old Mar 22, 2008 | 03:40 PM
SoonerFan's Avatar
Cletus
you locked it...you tell us the trick you used to do that
Old Mar 22, 2008 | 03:41 PM
SoonerFan's Avatar
Cletus
this is all the manual says....
GLOVE BOX
When locking or unlocking the glove box, use
the master key.
Old Mar 22, 2008 | 04:26 PM
WasatchY2KMax's Avatar
They lock? guess I never tried or looked for that matter. Now going to have to go out to the garage and look
Old Mar 22, 2008 | 05:16 PM
Craig_0530's Avatar
I choose not to comment.
GLOVE BOX
the master key.
So if I locked it, I should be able to open it with the same key? And that is the red one not the black ones right?
Sometimes, I wait until I get in the car to lock it.
Old Mar 22, 2008 | 05:30 PM
merlin2375's Avatar
In mine, the key doesn't go in all the way and it works fine, so I don't think that's your problem. Jiggle it around a little bit, whatever key you used to lock it should open it (as mentioned above). Maybe it's slightly jammed, be a little bit more persuasive
SoonerFan's Avatar
Cletus
the red is the valet key and will not work on trunk or glovebox...
the black key is the master...works for everything
Old Mar 22, 2008 | 05:40 PM
I was only given 1 black chip key when buying the car , In fact I had the locksmith do it and it wasn't even Keyed to that key he took a tooth out and now it works...85 dollars EH stuff appends :-/
Old Mar 22, 2008 | 05:41 PM
SoonerFan's Avatar
Cletus
I was only given 1 black key chip key, In fact I had the locksmith do it and it wasnt even the right key he took a tooth out and now it works...85 dollars EH **** happends :-/
how did you lock it
Old Mar 22, 2008 | 07:24 PM
mist max2000's Avatar
im sure u did this.. try every key you have? one way and the other...
Old Mar 22, 2008 | 07:57 PM
Professor's Avatar
Crow bar.
Old Mar 22, 2008 | 08:15 PM
RacerX1320's Avatar
pretty funny thread. Well hey if they steal your stuff leave a note or something asking how they did it.
Old Mar 23, 2008 | 05:02 AM
Redstone's Avatar
Unless you're not trying to use the red vallet key to open it then it shoud open unless something went wrong with the lock at that instant when you locked it. I have locked mine before and never had a problem opening it.
Old Mar 23, 2008 | 07:02 AM
Good idea! Leave the note inside the glove box so the thief is sure to see it
Old Mar 23, 2008 | 08:03 AM
Craig_0530's Avatar
Thanks Sooner for clarifying the keys for me. You are one of the most knowledgeable people on the org. What aren't you mod?
Mar 12, 2020 12:06 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Maxboy23
Sep 9, 2015 10:37 AM
Colossus
Sep 9, 2015 05:46 AM
