Courtesy Front Strut Tower Brace
I'm interested in getting a Courtesy Nissan Front Strut Tower Brace for my 2001 GXE Maxima, but one website says I need to saw off something to make it fit. Is this true? I don't want to void my warranty, nor do I want to saw anything on my car.
Please email me with recommendations or information.
Thanks!
Mike
michaeljrizzo@yahoo.com
Thanks!
Mike
Originally posted by 2maxguy
Just recently installed it myself. It's about a 10-15 minute job and nothing needs sawing off. Bar clears everything on engine, however I think it touches hood liner-no big deal. This is an easy mod, I give it 1 wrench!
Re: Courtesy Front Strut Tower Brace
Thanks!
Mike
Thanks!
Mike
-The front end is stiffer so it takes bumps/potholes a little harder
-a pothole on one side seems to be absorbed across the whole front(not bad though)
-the car handles corners really sweet
-able to take corners at higher speeds
Just installed the Courtesy FSTB this weekend. Took 15 minutes. Nothing to "saw off". Mine fits perfectly and doesn't even hit the hood liner (as other's have reported). Makes a huge difference in handling, as has been mentioned in detail in other posts. I highly recommend this mod!!!
Thanks!
Mike
Thanks!
Mike
Originally posted by alias
where do you get the 'Courtesy FSTB'??
Originally posted by JUDE
I'm not mechanically inclined. When you say to torque it to 35lbs/ft how do you know that its at 35?
Some members of the board have chosen to guess. I, myself, purchased a torque wrench at Home Depot for around $50.
http://www.homedepot.com and search on "torque wrench"
j/k!The only way you can torque anything correctly is with a torque wrench...you can pick one up at your local hardware store.
Originally posted by HulaMAX
You take a 70lb kid (35lbs per foot) and have him torque it for you...
j/k!
Michael,
I have a question. There were two types on the Homedepot site. 3/8" and 1/2"
Which one did you get?
Also, what would be a good place to "park your car in a level area"?
Thanks.
Thanks.
Originally posted by Michael98033
To add to HulaMAX's post and my previous one...I paid $50, like I said, but there was one less "nice" version for about $30. Good investment if you a Tim Allen type.
Originally posted by soundmike
Michael,
Thanks.
Michael,
Thanks.
I did the installation in my garage...which is as level as it gets. I think that, assuming you do not have a level area near you like a garage...find a parking lot to do it in...it really doesn't take that long.
Sounds good. Thanks for the info!
I'm probably gonna get the Courtesy FSTB as well given it's much cheaper and i don't really see anyone complaining about it. I just hope it fits the 02 bay.
Which one did you get? And, i know this is a frequent question but, do you really feel the difference even in normal day-day traffic or is it only when you push the max to it's limits?
Thanks again!
- Mike
Thanks again!
- Mike
I purchased the 3/8" because it is more granular. The 3/8" is designed for torques from 10 ft/lbs - 100 ft/lbs. The 1/2" is design for 25 ft/lbs - 250 ft/lbs. Don't anticipate needing the heavier duty one, so I opted for the one with smaller increments. For the FSTB, both can be set to 35 ft/lbs, so you can get either.
Thanks again!
- Mike
Thanks again!
- Mike
What's normal day-to-day driving???
HI Mike
there is a 3/8" Beam torque wrench for $18.97, 3/8" Click style torque wrench 10-100lbs
and another 3/8" Click style torque wrench 25-250lbs for $53.97
which one did you buy?
thanks
thanks
Originally posted by TaiwanMaxima
HI Mike
thanks
HI Mike
thanks
I chose the click-style because those are more sturdy than the beam torque wrench with the dial/needle gauge. It would also appear to be easier to ensure accuracy. I chose the 10-100 lbs since I saw the potential for granular applications between 10-100 lbs in future projects, unrelated to my Maxima, more likely than 25-250 lbs.
One more thing...
With the Courtesy, at least, if you install the bolts facing the windshield, you will not be able to get the wrench in place to tighten the top bolt on the strut tower...so you should install the bolts facing towards the front of the car.
hey mike
kinda having trouble tightening the bolt on the driver's side. there seems to be that black brace blocking the way. is there anyway i can tighten the bolt?
hey mike
You only have to cut a braket if you happen to get the early production ones which were for the 4th gens but fit the 5th gens by cutting about 1/3" off a bracket on the driver's side. If you buy it new from Courtsey, you will probably get one that fits perfectly....take off the bolts, put the bar on, tighten the bolts. Oh and make sure you do the install on a flat surface...
I purchased the FSTB from courtesy which fits perfectly. But the fact is that i can't tighten the main bolt on the brace (Driver's side) because of the airbox bracket in the way. Is there someway to tighten it?
Yea, its the airbox. So u say remove it temporarily? will i mess up any sensors in the process? just wondering
thanks
thanks
If that's not it, do you have a digital camera you could take a pick with?
Re: waiting
Originally posted by sascuderi
Just ordered my FTSB from Courtsey tonight. Using ground UPS from Texas to NJ. Wonder how long it will take to get here???
dvcamp
Sep 18, 2015 10:17 AM
