Project: Adding shock sensor to factory alarm.
Old Oct 30, 2001 | 06:05 PM
RussMaxManiac
I will be installing a Dual Stage Shock Sensor on our Factory Alarm systems. Our Factory Alarms are fair for what they do. Personally most of us would keep them if they had shock sensors and other type of connections. I will be only using the full trigger on this sensor since our alarm does not have pre-warns.
This project should be completed by this weekend with pictures and a detailed write up. I will be picking up the supplies tomarrow after work hopefully to complete this job. The factory alarm does not work off a negative system, so I will be using multiple components to make this work and will have it all listed when the job is completed after I make sure it works properly.
Total project $$$$ About $20 bucks total.
Looks like I will be the first person to attempt this. No one else has every posted in 6 yrs of ever doing this. I am willing to be the beta boy!
Old Oct 30, 2001 | 06:30 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Good luck!
Old Oct 30, 2001 | 08:59 PM
Rob'sAE's Avatar
You're Faster, I'm Better
Re: Project: Adding shock sensor to factory alarm.
YES!! I have been wanting to do this for so long. Let me know how it goes so that I can go get mine done up too. What shock sensor are you going to use? Is there the possibility of using more than one shock sensor, one up front and one in the back??
Old Oct 31, 2001 | 05:51 AM
victor's Avatar
is that $20 amount including the sensor too?? i'm thinking it's not, but i'll probably do this after you get it to work.
Old Oct 31, 2001 | 07:10 AM
TimW's Avatar
The silent but deadly Moderator
or....
you could do this....
http://www.codl.com/its.html
Old Oct 31, 2001 | 03:51 PM
RussMaxManiac
Re: Re: Project: Adding shock sensor to factory alarm.
Yes you can use 2, I am starting with one right now!
Old Oct 31, 2001 | 03:52 PM
RussMaxManiac
The sensor costs $10 bucks from autotoys.com.
Old Oct 31, 2001 | 04:01 PM
HulaMAX's Avatar
Good luck!!! I can't wait for the write up.
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
Stagnet04
Sep 14, 2015 11:28 PM
