Trans Mount (Location)
Old Apr 2, 2008 | 07:33 AM
mmendezm3power's Avatar
Black02Max
Having some trouble picturing where the Trans Mount is located in our maxima. Has anyone replace their Trans Mount and taken any pictures?
Thanks,
mmendezvq35
Old Apr 2, 2008 | 08:05 AM
NmexMAX's Avatar
dot dot dot ...
Engine/tranny mounts are located on all 4 ends of the engine.
1 next to the Fr exhaust manifold, 1 next to the starter (under airbox), 1 near the R manifold, and 1 near the PS fluid reservoir.
Why, what's the problem? tThe one that sits on top the starter might be the one you're trying to look for since it sits closest to the tranny area.
Old Apr 2, 2008 | 08:26 AM
Black02Max
I was told that I needed to replace my Trans Mount and was debating if I should undertake this task. I already replace the rear one but I paid 60$ to install it, just wanted to save some money if I am able to install it myself.
it sounds like i may be able to.
Old Apr 2, 2008 | 10:38 AM
AceofSpds's Avatar
wat
Its under where the stock airbox would be, very easy to take out. Just take out the battery, battery tray, intake assy., put a jack under the trans, and its like 4 14mm and one 17mm i think.
Old Apr 4, 2008 | 05:39 PM
Black02Max
here are some pictures, easy task! saved myself $60!
Attached Thumbnails Trans Mount (Location)-before.jpg   Trans Mount (Location)-after.jpg
Old Apr 4, 2008 | 07:27 PM
wyche89's Avatar
is it that easy with the motor mounts too?
Old Apr 5, 2008 | 09:56 AM
NmexMAX's Avatar
dot dot dot ...
In our Maxima world, tranny mounts = motor mounts and vice versa. The 'rear' mount is a PITA. Do a search, there are members that have done this on their own and also have been kind enough to document the process as well.
wyobbagy
Jan 3, 2023 12:03 PM
vball_max
Sep 17, 2015 10:01 AM
spidgeon
Sep 9, 2015 03:36 PM
