steering question
Old Apr 4, 2008 | 08:15 PM
gotendbz1's Avatar
steering question
soemtimes when i'm braking the car will to pull either to left or right, usually right, i pretty sure it has pulle dto the left a few times also. It only seems to happen when i'm braking, and when it happens it will pull in that direction until i manually correct it by turning the wheel. It pulls about maybe 10 degree either way. also my PS fluid is kida bad so i'm gonna change that out and see if it helps. Any Ideas?
Old Apr 4, 2008 | 08:25 PM
SoonerFan's Avatar
Cletus
search - common problem (hint: there is a thread in the top 10 with the answer)
newbie thread
Old Apr 4, 2008 | 08:44 PM
CMax03's Avatar
Check you front suspension for defects wheel bearings, lower control arm bushings, strut mt, tierods balljoints...Can you hear any sounds?
Old Apr 4, 2008 | 08:46 PM
SoonerFan's Avatar
Cletus
Old Apr 4, 2008 | 08:55 PM
gotendbz1's Avatar
newbie thread
i searched for 'common problem' and couldn't find anything. maybe you can help.
Old Apr 4, 2008 | 09:05 PM
SoonerFan's Avatar
Cletus
i did
post in the newbie thread
Old Apr 5, 2008 | 06:15 AM
gotendbz1's Avatar
i did
so your the ******* of this forum huh? anyone esle with a useful reply beside soonfag, who is most likely to respond anyway.
Old Apr 5, 2008 | 06:53 AM
jasonmax's Avatar
it could be your brakes, which are either worn out or not balanced.
Old Apr 5, 2008 | 07:13 AM
gotendbz1's Avatar
can warped rear rotors cause this?
Old Apr 5, 2008 | 09:52 AM
jasonmax's Avatar
yes, they can. especially when braking pads are not installed correctly.
Old Apr 5, 2008 | 12:20 PM
SoonerFan's Avatar
Cletus
lowpost99
Oct 26, 2025 06:53 PM
BrandonCause
Sep 14, 2015 10:41 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
Johnny9595
Sep 3, 2015 05:18 AM
