Acc/On power in the engine bay...
Old Oct 31, 2001 | 10:12 PM
TimW's Avatar
The silent but deadly Moderator
anyone know the best place to get switched +12V under the hood? I dont want to go through the firewall, I know there has to be something under there I can connect to.
Old Oct 31, 2001 | 10:16 PM
BigDogJonx's Avatar
Re: Acc/On power in the engine bay...
Looks like Timmmeh is trying an alarm fix.........
Old Oct 31, 2001 | 10:47 PM
TimW's Avatar
yeah...
say... did you investigate simply grounding the pink wire (relay to Hlamps side)? I looks like that would work... *looks* that is....
well, I will use a relay to close ground on the HIDs directly... I still dont like the highflash (with lights off) issue. BUT I really need to get the alarm fix done before I screw up a ballast by accidently hitting panic while popping the trunk or something.
Old Oct 31, 2001 | 10:48 PM
TimW's Avatar
oh...
and I went probing around with the fluke meter tonight... almost everything I found was constant power
Old Nov 1, 2001 | 02:19 AM
BigDogJonx's Avatar
Re: oh...
Well in that case, my MAF wire should be just fine. I talked to a EE expert and he said that the sensor in there does not get reading off voltages. So the relay I have tapped off that is not going to obscure the readings.
The readings on that sensor is done via ohmage. he said that the some 15milliamps it takes to drop that switch in the relay is not enough to screw damn near 99% of the things in the car, I mean the amount of power it takes to drop that switch in the relay is about the same if you tapped a LED to it.
No harm, so me, I am going to leave it alone.
Dixit
Old Nov 1, 2001 | 07:09 AM
TimW's Avatar
I agree...
but my service manager isnt an EE... Not sure if he even passed potty training. thats the only reason I'm not clamping on there.
Old Nov 1, 2001 | 07:43 AM
Colonel's Avatar
Old Fuddy Duddy
Re: I agree...
but my service manager isnt an EE...Not sure if he even passed potty training...
Tim you made my day. I was LMAO on that comment....
lowpost99
Oct 26, 2025 06:53 PM
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
cruce91
Sep 20, 2015 10:23 AM
trungg86
Sep 4, 2015 04:58 AM
