'00 fed spec O2 sensor help! **pics**
Old Apr 19, 2008 | 03:19 PM
00MaxSE's Avatar
Pointy Elbows
Searched a bit, but couldn't find any specifics.
Got a P0153 (sensor 1 bank 2) and P0133 (sensor 1 bank 1).
For the fed spec's there are only 3 sensors and these are the 2 before the cat.
The first one I can't get room for my ratchet to turn in there.
Here's what I'm using.
I got my sensors from oxygensensors.com and theyre the Walker brand ones.
They called for the same sensor for both.
This is so frustrating. Plus I'm exhausted right now.
Old Apr 19, 2008 | 03:57 PM
pmohr's Avatar
No more Maximas...
You replacing the downstream, too? P0133 and P0153 are both upstreams.
Old Apr 19, 2008 | 04:06 PM
nlmaxima's Avatar
You need to replace both sensors closest to the engine. A 7/8 inch wrench should remove the O2 sensor, careful not to round it and you may have to heat the base of the sensor and y-pipe.
Old Apr 19, 2008 | 04:07 PM
00MaxSE's Avatar
Pointy Elbows
No, I'm replacing both up streams. I've replaced the downstream (after cat) one before, but the up stream ones have never been replaced since I've owned the car.
EDIT: it turns out both sensors DO have 3 wires. I just couldn't see the black wire on the one from where I was looking. I got that one out and I'm going to splice the wires. The first one is still stuck.
Old Apr 19, 2008 | 04:08 PM
pmohr's Avatar
No more Maximas...
Ah, gotcha. The 'further downstream' comment threw me.
As nlmaxima said, either a 22mm or 7/8" wrench should help you in there. If you're going to rewire anyway, you could cut the harness connector off and use the box end of the wrench. That way you won't be as likely to round off the flats on the sensor.
Old Apr 19, 2008 | 04:13 PM
Mr.Nissan's Avatar
I Would recommend. alot of PB Blaster. A 7/8 wrench works or a 22mm, I recommend you use a larger ratchet. Good luck.
Old Apr 19, 2008 | 04:31 PM
SoonerFan's Avatar
Cletus
liquid wrench
open end wrench (a racket wont work)
Old Apr 19, 2008 | 05:21 PM
00MaxSE's Avatar
Pointy Elbows
Well 2 hours later, and nothing. The one further downstream that I got out, didn't have much slack in the wire, so i wouldn't have room to strip and splice since it's kinda up there. I tried to disconnect the whole sensor, but they've got those little snap in zip tie connectors that are impossible to get off. I gave up and put it back in.
I'll buy a 22mm open end wrench and try the front sensor next time.
The neg battery terminal was disconnected the whole time, so maybe the SES light won't come back on and i won't have to change them! :fingerscrossed:
Old Apr 19, 2008 | 05:36 PM
SoonerFan's Avatar
Cletus
for the one you are removing...remember, you are removing it....cut the wire and the plastic connectors with small wire cutters...get all that out of the way, and its easier
Old Apr 19, 2008 | 05:47 PM
00MaxSE's Avatar
Pointy Elbows
the wires are tied down up under the car and I couldn't get to the connector in the engine bay. Argh! I was going to cut the wires, but then I figured i wouldn't be able to strip and splice the wires since they were recessed up there. Not much room to get the stripper and crimper up there.
Old Apr 19, 2008 | 05:53 PM
SoonerFan's Avatar
Cletus
thats why you buy the proper ones ...no need to splice...has correct harness
Old Apr 19, 2008 | 05:56 PM
00MaxSE's Avatar
Pointy Elbows
^ Meh, I did that before for the one after the cat. Was trying to save like a hundred bucks or so.
How much was that one?
Old Apr 22, 2008 | 10:24 AM
ChevelleRH's Avatar
On how much and where did you get it... I just got a P0141 - Rear O2 Sensor Heater (Bank 1) code on a fed. spec, trying to figure out what Im going do to replace it or at least solve the code. Which 02 does this correspond to?
Last edited by ChevelleRH; Apr 22, 2008 at 10:25 AM. Reason: trying to convey what im mean and failing
Old Apr 22, 2008 | 10:30 AM
SoonerFan's Avatar
Cletus
i get my sensors from daveb...around $160 i think
Old Apr 22, 2008 | 01:10 PM
Professor's Avatar
So where is bank 1 sensor 2 on the fed spec models ? i dont have the on on the bottom like it shows in the pic sooner posted. and there $104 at advanced auto
Old Apr 22, 2008 | 01:49 PM
phatboislim's Avatar
^x2 i looked at soonerfan's sig..its a cali spec..i figured it was the same, but i'm not sure if its the same for fed spec
Old Apr 22, 2008 | 02:35 PM
00MaxSE's Avatar
Pointy Elbows
There's a pic from the FSM somewhere on here. Search for it. I saw it the other day.
Old Apr 22, 2008 | 08:12 PM
ChevelleRH's Avatar
Maybe...?
Old Apr 22, 2008 | 08:36 PM
SoonerFan's Avatar
Cletus
rear bank on the y-pipe...between where the y-pipe meets the exhaust manifold and the precat
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Apr 23, 2008 | 03:53 AM
nlmaxima's Avatar
On a 2000 Fed the #2 sensor is after the main cat. So Bank 1 Sensor 2 is after the main Cat and before the B-Pipe.
Old Apr 23, 2008 | 04:01 AM
Professor's Avatar
grrrrrrrrrr the one i got is a 3 wire.... it looks like a 4 wire in that pic, the pdf link is not working Sooner.
Part is a bosch 13350
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
