need help please ses light on
Old Apr 20, 2008 | 11:23 AM
nismowolfe's Avatar
My vapor canister got broken and I need to replace it and the vent control valve since Ive searched and seems like you pretty much have to do both can someone give me the part numbers for both please. I found the vapor canister on everything nissan but not the vent control valve or do they both come together thanks.
Old Apr 20, 2008 | 11:34 AM
maxximaa's Avatar
no, both do not come together.
i bought both and that's what you need.
the part numbers are different from US to Canada.
you need both becoz the two bolts that's holding the valve to the canister are badly rusted and will break when you try to unbolt it.
you can try these and see if they work.
Canister - 14950-4L602 OEM, 14950-4L60C replacment
Valve - 14935-5M00A
Bolts(which mate the valve and canister together) - 08363-6202D
hope this helps.
good luck
Old Apr 20, 2008 | 04:47 PM
nismowolfe's Avatar
thanks alot if anyone knows the U.S. part #s let me know or can confirm they are the same thanks
Old Apr 2, 2009 | 01:18 PM
scottygill's Avatar
im looking for the same fix. for my 03 the canister is 14950-4L60C
there are two control valves the dealership told me one of which is similar in number to the ones posted by maxximaa dealership $253
14933-2Y90A valve assy cont is about $75
14935-5M00B valve assy co is about $75 they are similar but bring the broken one to the dealership when purchasing
im about to find out if my bolts are going to break or if i can just replace the control valve. im getting code p0455 and they said that the control valve is stuck open causing my car to smell like gas inside but its still drivable until parts come in.
Call your local dealership, im guessing the difference in our part number for one of the valves from A --> B is the model year? mines an 03 his an 02? or maybe thats the canadian / usa difference
Old Apr 2, 2009 | 02:20 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Lemme guess, you pulled an evap canister code?
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
