Input Shaft Bearing?
Old Jun 10, 2008 | 05:18 PM
Weeble1's Avatar
The Whistle go WOOOOO
I'm pretty sure my ISB is going out. It has all the common signs (chatter stops when I push the clutch in and I can also hear the chatter rise with the RPM in gear). I had the same issue with my 4th gen. I also have a pretty nasty tranny leak. Could these 2 be linked? The vibration isn't too bad right now but I don't want it to get worse. Can somebody help me out here? Does this need fix ASAP? If so how much should it cost? I know it's not a cheap fix. Thanks a lot.
Josh
Old Jun 10, 2008 | 07:41 PM
jvienneau's Avatar
Josh
Yes, the wobble from the bad bearing causes the leak. It's not going to self-destruct as long as you keep oil in it. Probably $600-$1200 depending on who's doing the work.
Old Jun 10, 2008 | 07:44 PM
Weeble1's Avatar
where do you think it leaks from and how much do you think it all is? Thanks for the reply!
Old Jun 11, 2008 | 08:53 PM
metalpiotr's Avatar
03 Maxima, 6spd
I think it leaks from the axles (where the axles meet the transmission). in my 4th gen it ended up getting so bad, the axles got damaged too (because there was play in the differential).
Old Jun 11, 2008 | 11:28 PM
makaveli_13's Avatar
I have the exact same problem.... A loud chattering while the car is in gear w/ no gas being given, like he said, as soon as you put the clutch in its gone.! could there be a possibility it might be a driveshaft?? i did lower my car recently... thats why..
Old Jun 17, 2008 | 07:59 PM
BUMP!!!!
Old Jun 18, 2008 | 05:31 AM
Weeble1's Avatar
doubt it's drive shaft... that moves when the car moves. Either ISB or Throw out Bearing is my opinion. mine is getting changed this weekend so I'll let you know what happens.
Old Jun 18, 2008 | 07:05 PM
cool thanks man.
Old Jun 19, 2008 | 07:38 AM
VqMoNsTeR's Avatar
i had the same problem. my tranny actually crapped on me on the way to work. 1st, 6th and rev gear didn't work. all started from that noise. common problem tho, i think it should be a recall. u can bring ur car down to md. ill put another trans in lol. i did my girls auto, my 6spd and my buddy 6spd, all 02 maxs.
Old Jun 19, 2008 | 07:48 AM
Merlyn's Avatar
And... I'm out
You fail VqMoNsTeR I am heading down there tomorrow to do the work... j/k
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
