2006 HLSD 6-Speed in an A33(B)
Old Jun 23, 2008 | 02:50 PM
  #41
Merlyn's Avatar
And... I'm out
Originally Posted by trigger005
cant believe i missed this thread this whole time.
thats pretty awesome man. i'm impressed by your dedication to the max.
that clutch is badass
Yea, the clutch is pretty bad *** but not functioning properly... If this was not my 10th time taking my transmission out I prob would try to get the clutch / flywheel to work but I am sick and tired of my drive train so I am getting my fidanza flywheel worked on and throwing a new clutch in the car...
Technically yes, my car runs with the Cusco Twin Disc Carbon Clutch in it, as I drove to VA and back this weekend, but it is not worth my time nor effort, was a cool idea, and can be done, just not by me, right now
Old Jun 23, 2008 | 08:52 PM
  #42
03blackmaxse's Avatar
If u were doing everything over again, would you use the same clutch? I'm also getting a new tranny soon, will need a clutch as well and some suggested to just go OEM (i'd like to find something with a shorter clutch throw).I've been putting some thought into the flywheel and udp, but can't really justify it b/c i'm not too keen on putting extra cash into the car, especially for performance (which is like a forbidden word now in ontario)
Old Aug 19, 2008 | 09:03 AM
  #43
knight_yyz's Avatar
Toolie
Thread is a little old but I just did the same tranny swap. With the short shifter from watkins in there the shifts are relly freaking knotchy, I'm hoping this will get better as the tranny gets worked in. When I first got into the car it didn't want to go in reverse. Just wondering if you had the same problem merlyn?
Running fidanza flywheel and exedy stage 1, there is a little chatter in first, gearing up is ok, gearing down there is chatter also. I hope this is going to get better also. there is only 150km on the clutch so far.
Old Sep 13, 2008 | 01:06 PM
  #44
knight_yyz's Avatar
Toolie
old thread but i know a few people want to see the difference in tranny's due to final drive. run 9 is 03 tranny, run 12 is 06 tranny. dyno is in mph. 4th gear pull
Old Sep 19, 2008 | 09:15 AM
  #45
Deckdout2's Avatar
Play with my balls
Holy Fawk that's quite a jump with the just the FD change. I'll bet with the raised rev limit as nismology was stating, this would be an ideal setup.
Old Sep 19, 2008 | 01:42 PM
  #46
knight_yyz's Avatar
Toolie
I still don't see the point of a higher rev limit when there is no power up there
Old Sep 19, 2008 | 02:15 PM
  #47
Tippy Toes's Avatar
supercharger anyone?
knight yyz did you try some solenoid gear lube. I remember this made shifts to my stock 03 tranny 100% better. I could be way off though.
Old Sep 19, 2008 | 02:34 PM
  #48
Deckdout2's Avatar
Play with my balls
I have (and will have more) the components to back it up. Most people running stock with bolt-ons will not see power up there.
Old Sep 19, 2008 | 02:44 PM
  #49
knight_yyz's Avatar
Toolie
i'm running motul in the gear box. I lubed up the parts I could with synthetic grease. I had a hard time shifting when it was first installed, but I love it now. Shifts are very smooth and I was able to keep my watkins sts in there.
Old Sep 19, 2008 | 02:45 PM
  #50
knight_yyz's Avatar
Toolie
that's my point, unless the IM is gutted and/or you are cammed the power curve does not justify a higher rev limit.
Old Sep 19, 2008 | 03:15 PM
  #51
nismology's Avatar
I thought it was implied that the powerband would dictate how high the redline would be. That goes without saying. Either way, making power past the stock redline has been done and isn't terribly hard. My motor and deckout's definitely will...
Old Sep 19, 2008 | 05:56 PM
  #52
maxximaa's Avatar
sorry i havent been following up with the thread but would an 06 auto tranny fit an 02 auto tranny car?
Old Sep 19, 2008 | 06:08 PM
  #53
pmohr's Avatar
No more Maximas...
Fail.
This thread is about a manual, not an automatic (re: your first post)
And would it bolt up? Sure.
Would it work? Nope.
Old Sep 20, 2008 | 03:43 AM
  #54
NismoCefiro's Avatar
Im piecing together a auto to manual swap for my i30. Would vq35 trannys bolt up? If not should I get a 5th gen 5 speed or 6speed anniversary edition trans? I got a quote from nissan for 2200 on 5speed with LSD.
Old Sep 25, 2008 | 10:34 AM
  #55
pbn85's Avatar
quick question guys
Im going to get a new 6th gen hlsd tranny from dave b but it doesnt come with clutch and flywheel. Can I use the existing clutch and flywheel from my current 03 tranny with the 6th gen one??
Old Sep 25, 2008 | 10:37 AM
  #56
nismology's Avatar
Yes.
Old Sep 25, 2008 | 10:39 AM
  #57
pbn85's Avatar
thanks! The other deal didnt fall through...so Im getting a new one. ah well
Old Sep 25, 2008 | 12:54 PM
  #58
Deckdout2's Avatar
Play with my balls
you mean, "did" fall through?
Old Sep 25, 2008 | 03:21 PM
  #59
knight_yyz's Avatar
Toolie
i'd be careful with the fly wheel, it might be "burnt" it may need re-machining depending on condition. When I did mine I bought the fidanza, turns out I would have had to re-machine the old one.
Max139617
Oct 19, 2016 11:34 AM
Smackasmith
Feb 1, 2016 12:40 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
I<3 A32's
Sep 10, 2015 11:07 AM
