Power Difference. 02 Max vs 05 Alty SE-R
Hey guys,
In my quest to find a motor I've found a 14k '05 Alty SE-R motor for $700. It was wrecked on the front end and broke a valve cover and that's it.
What are the power differences between my 02 max 3.5, and the 05 SE-R 3.5?
I know that my max is rated at 255hp, and the Se-r is rated at 250hp. My question is this, are the cams different? Rods/pistons? Am I going to notice a loss in power? Anything I need to be worried about?
Andy
Andy
Unless the cam specs and ECU programming are different, I'd guess there is little to no noticable difference. Sometimes the exhaust system makes the difference between models and sometimes they just rate the engines differently so the more expensive car has more advertised horsepower.
To be honest I believe the difference is in the ECU programming and they were rated @ 260 Hp! I got smoked twice by one @ one of our local dragstrips! I was really green at Drag racing with the christmas tree starting lights. My RT was .527 and I believe he jumped me with a .050 RT! He beat my off the line and really never gained any more ground! 1st race he beat me by a full car and the second race 1 fender! both of us were autos and I definitely needed work on a better launch!
1 car length does not equal "smoked".
260 HP and an extra gear in the automatic only beating a 255 HP Maxima by 1 car or less makes the 260 HP rating a little suspect unless the gear ratios in 1 through 3rd are exactly the same for both transmissions.
And, if anyone cares to read the AM thread, they engines are identical to the A34.
Advertised HP numbers are for marketing and magazine racers.
Here is some info regarding the 4A and 5AT:
http://forums.maxima.org/showthread.php?t=131717
http://forums.maxima.org/showthread.php?t=140957
http://forums.maxima.org/showthread.php?t=301536
http://forums.maxima.org/showthread.php?t=168625
Who mentioned ET's? He got the hole shot and you can't make that up within a 1/4! I'm not stock and it was my second time running my car thru the 1/4 mile...I lost due to inexperience if we were running a 1/2 mile he was all mine... I had stock suspension at that time, so I can't turn up the Illuminas to prevent that undesired weight transfer off my drive wheels! Plus I never dog my car trying to come out the hole really hard and violent like a batt out of hell! I've ran 14.8's b4 and I'm sure with a little practice I can take this Auto to 14.0 as is! It's beat a 350Z and 05 Mustang Gt in a standing mile with ease by 100-125 yrds!
That is my point. If the hp number was accurate, the 5 hp extra plus the better gearing should make a larger difference in the quarter mile-gearing can really make a difference, that's why the hp rating seems suspect to me.
lowpost99
05-16-2021 11:18 AM
trungg86
09-04-2015 04:58 AM
