Cruise Control
Old Jun 20, 2008 | 09:42 PM
sunstream453's Avatar
Cruise Control
my cruise control hasnt been working. i get the cruise light to work, but it will not set and the set light doesnt come on. so far, ive established that the following are working:
ascd clutch switch
ascd brake switch
stop lamp switch
p/n (gear select) switch
TPS
i have a bad r/f abs sensor (abs light on)
any ideas?
Old Jun 20, 2008 | 09:54 PM
SoonerFan's Avatar
Cletus
we need a year
Old Jun 20, 2008 | 09:59 PM
oh ya. well, 03 6mt
Old Jun 20, 2008 | 10:04 PM
SoonerFan's Avatar
Cletus
Originally Posted by sunstream453
oh ya. well, 03 6mt
cool...because on the 00-01, its cable cruise...and electronic on the 02-03.
i dont know the answer...but now it will make is easier for others to help
Old Jun 20, 2008 | 10:22 PM
yeah. ive been going over the operation diagram from the FSM and it sort of looks like an operating ABS circuit is necessary for the control. im not sure though, but if thats true i would guess that its for the vehicle speed input
Old Jun 21, 2008 | 07:06 PM
yeah...ok then
Old Jun 21, 2008 | 07:46 PM
Professor's Avatar
i have a issue with mine also, it surges all the time, its up and down and up and down,
Old Jun 23, 2008 | 08:40 AM
majesticmaxima's Avatar
My ABS light was on for a year or so and the CC was fully functional, i think they are unrelated. I have a 02 6sp, however it was the rear sensors that were bad, not sure if that makes a difference.
Old Jun 23, 2008 | 08:41 AM
Cable problem
Old Jun 23, 2008 | 08:52 AM
ascd clutch switch
ascd brake switch
stop lamp switch
TPS
any ideas?
ASCD steering steering switch
Old Jun 23, 2008 | 09:35 AM
Professor's Avatar
Cable is fine, no tightness
Old Jun 23, 2008 | 10:31 AM
you should take a video of this, mine surges and its normal, its just how the cc works, but its not really serious, just annoying sometimes, but if yours is really bad its different. we would need to see it to get an idea.
PS: my switch is fine im pretty sure. i can get the lights to work and im pretty sure it sends a signal to the ECU when i hit set. either way, im in the process of getting a new abs sensor, so well see if that does it.
Old Jun 23, 2008 | 10:46 AM
Professor's Avatar
Its not a heavy surge, but its annoying, like pressing the gas, releasing slowly and over and over.
Old Jun 23, 2008 | 10:58 AM
does it happen constantly? could be a vacuum leak in one of the cc units
Old Jun 23, 2008 | 01:29 PM
Professor's Avatar
Its constant like a up and down ride, i replaced the vacuum lines and still does it.
Old Jun 23, 2008 | 01:41 PM
what i meant was a vacuum leak in the actual control device itself. sounds kind of like what happens when a master cylinder is leaking vacuum. leaks out until its low and then you have to recover. for cc that would mean slowing down until the vacuum is low enough for it to be noticed and then speeding up to recover. i dont know though, just my speculation. not a lot can go wrong with a cable cc
Old Jun 23, 2008 | 03:23 PM
Professor's Avatar
That sounds about right, ill have to test it with a vacuum gauge when i get a chance, its not a major concern because i dont travel alot on open roads to used it.
Old Jun 23, 2008 | 03:29 PM
yeah, same reason i havent dealt with it over the past 1.5 yrs it hasnt been working. i just figured it was time. lol
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
