Weird noise???
Weird noise???
I notice my car making a knocking noise on the passenger side when I accelerate slowly. As soon as I let go of the gas pedal it goes away, it also happens when I slowly accelerate and swirve to the left it makes the noise but goes away when I swirve to the right. I don't think it's the cv joint. What could be causing that. Could it be tirod. Does anyone have any suggestions? It sounds like a hammer tappinp underneath and sometimes it almost sounds like something bending or rubbing?
Jack it up and check suspension items: sway bar endlinks, brake hose security, Lca bushings, strut assy security, engine/trans splash shield security, brake rotor backing plate, and tire clearance!
Check your boots and see if they look damaged or what not. A lot of miles? Even if the boots look new, it still could be internally. Another scenario could be exhaust mounts. When you accelerate, your engine rocks backward causing motion. I had the same issue.
Thanks a lot guys!
It is now fixed. I appreciate everyone's input. It was a drive shaft that needed to be replaced. Got it done today and the noise is gone!
No more clunk noise.
Yeahhh!!! My MAX is now running smooth again.
HerpDerp1919
Sep 29, 2015 02:02 PM
