brake pedal press too far
Old Jun 23, 2008 | 11:20 PM
jjj's Avatar
jjj
my 02 max brake pedal presses to far down. new brakes, rotors (4), and fluid (with bleed).
Old Jun 23, 2008 | 11:35 PM
SoonerFan's Avatar
Cletus
you mean the pedal goes down further than it used to?
Old Jun 23, 2008 | 11:49 PM
AceofSpds's Avatar
wat
bleed em again
Old Jun 24, 2008 | 01:50 AM
JonBlz's Avatar
a.k.a. STuNtMAN
check for leaks and make sure calipers are not seized check fluid and lines for leak and all buddy
Old Jun 24, 2008 | 11:26 AM
merlin2375's Avatar
Originally Posted by chopstix2nrz
bleed em again
+1 and make sure you bleed them in the order specified in the FSM.
Old Jun 24, 2008 | 10:32 PM
Dudeman's Avatar
Not trying to question your manliness, but get a pro to do your brakes. I never mess with brakes or steering, cuz if you mess that up, you are asking for a wreck. Sounds like you bled bubbles into your hoses or cut/cracked one of them. Maxima pedals are fairly solid.
Old Jun 24, 2008 | 11:31 PM
CMax03's Avatar
Yeah bleed them as per the FSM...Be sure to either unplug the ABS pump/module or disconnect your battery negative cable.... while bleeding your brakes! If you're still experiencing a low peddle after your thru bleeding all your brakes, you may have a worn M/C!
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
