Ignition Timing
Old Jun 25, 2008 | 12:00 AM
CMax03's Avatar
Ignition Timing
I noticed that a few guys dislay thier list of mods. I'm curious on how some of you guys adjusted your ignition timng? I wasn't aware that the timing was adjustable on any of the VQ's unless you have a stand alone ignition...
Old Jun 25, 2008 | 12:18 AM
SoonerFan's Avatar
Cletus
please search for the info...it is available...trust me
Old Jun 25, 2008 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
It can be done using most any OBDII ddata logging / scanning software. AutoEnginuity / Cipher, etc. for other known readers.
Most on here had it done at the dealer. The dealer charges, typically, 1 hour of labor.
I can do mine at will using Cipher, but it (Cipher) did cost a pretty penny, and I use it for other things too. The same can be done w/ the AutoEnginuity using the Nissan tool. Less expensive than the Cipher, and it does the same thing.
Keep in mind it is BTDC.
Old Jun 25, 2008 | 10:55 AM
CMax03's Avatar
If you're not gonna help please don't reply! I've checked the How to's and the subject clicked on isn't what pops up! So go enjoy yourself with both your hands and some astroglide!!!!
Old Jun 25, 2008 | 11:28 AM
AEMAXIMA01's Avatar
did you try replacing "showthread" with "oldthread" in the url (w/out quotes)?
Old Jun 25, 2008 | 11:42 AM
NmexMAX's Avatar
dot dot dot ...
Wont work for that particular situation because it only works for threads, not direct single post links.
Old Jun 25, 2008 | 01:39 PM
SoonerFan's Avatar
Cletus
Old Jun 25, 2008 | 01:46 PM
SoonerFan's Avatar
Cletus
proof that the info it can be found...if you are actually trying
http://forums.maxima.org/showthread.php?t=114304
http://forums.maxima.org/showthread.php?t=111135
http://forums.maxima.org/showthread.php?t=110653
http://forums.maxima.org/showthread....timing+advance
Old Jun 25, 2008 | 10:47 PM
CMax03's Avatar
I doubt it, I've been a member for a little while and I'm still learning how to use this forum thoroughly! What I did try was a forum search and it pulled up 2 separate post. I'll keep playing with the forum and I'll get to where you guys are hyberwise! My talent/gift... is my mechanical inclination that god gave me! So... to Soonerfan and those of the like, learn to use your gift and knownledge to help others that have the guts to ask for help or ask questions that they may not be clear on! Don't hate! Participate! We're suppose to be on this forum to learn and educate on the common ground regarding our Nissan Maxima enthusiasm. Please...If it bothers you that much with some of these questions that were asked years ago, then please either help us Know where to look or just don't respond please! I do it all the time.....
Old Jun 25, 2008 | 10:52 PM
SoonerFan's Avatar
Cletus
so we should continue to spoonfeed people when the same question is asked AGAIN AND AGAIN...when we KNOW the info is avaliable
Old Jun 25, 2008 | 11:59 PM
CMax03's Avatar
I'm not sure whom asked you again and again! But I'm sure I posted a question that required a simple answer regarding someone's mod listing of 17* ignition timing. If it is a problem....simply don't respond, Soonerorlaterfan!!!
Old Jun 26, 2008 | 12:30 AM
SoonerFan's Avatar
Cletus
this question has been asked before...thats evident by the links i posted. and thats only a small fraction of the threads/posts that address your question.
so,
you think its ok to ask a question when the info is available?
you thinks its ok to perpetuate spoonfeeding?
you think your question is so important that it requires its own thread?
you think you are too good to ask a newbie question in the newbie thread?
you think its ok if every single person start a thread for every single question?
and there is no rule stating that people can only post if they are spoonfeeding. there is; however, a rule that requires people to search before posting.
tsi6001
Oct 3, 2022 10:23 PM
trasmadean
Jan 20, 2018 05:05 AM
intimidator
Sep 5, 2015 07:23 PM
Slamrod
Sep 3, 2015 07:38 PM
evonder73
Sep 1, 2015 02:21 PM
