EVAP Canister...quick fix?
Don't go the cheapo route on that part if your fix doesn't work you'll burn out your SES bulb, plus when that part fails it sucks your power and increases you MPG's. I equate it to re-using a Trojan, thats something you should NEVER do.
guys... EVAP does not DO ANYTHING! epoxy, and fix that. it will not effect your MPG at all.. it is only there to release pressure in the fuel tank. you can reprogram your ECU to not even read the EVAP codes and you're good to go for emissions.
tseng1023
10-15-2015 08:30 AM
