stinky cabin
Old Jul 2, 2008 | 10:47 PM
hotstartup's Avatar
stinky cabin
so the inside of my car would not smell very good once i put the fan on. today i got the cabin filter out, it was filthyyyyy and smelt soo bad. cleaned it out, and washed it. hopefully it helps.
Lesson for those of you having anything similar to this, check out the cabin filter, it most likely is in bad shape.
Old Jul 3, 2008 | 05:31 AM
hi-tek22's Avatar
so replace it
OEM air filter FTW
give Dave B a call
Old Jul 3, 2008 | 05:56 AM
jkpgt96's Avatar
Stupid question, but where under the dash is it? I am gonna be doing this tomorrow and don't feel like having to look for it...not that it would be hard to find...Is it under the dash on the driver side?
Old Jul 3, 2008 | 07:46 AM
jdm01se's Avatar
2002 and beyond had them, correct?
Old Jul 3, 2008 | 08:01 AM
hotstartup's Avatar
there is a diy on it jk. here is a link http://www.innerbean.com/housecor/cabin_filter.html
it was in the 02+ but i believe the filter slot is there in the 5 gen too
Old Jul 3, 2008 | 08:21 AM
jasonmax's Avatar
dont unplug the yellow plug, you'll get a airbag light.
Old Jul 3, 2008 | 08:23 AM
jkpgt96's Avatar
Noted...thanks!
Old Jul 3, 2008 | 08:28 AM
jasonmax's Avatar
if yours is still the paper one, I suggest you replacing it with the carbon one, which works very well.
Old Jul 3, 2008 | 08:53 AM
sergey85's Avatar
are the oem ones good
Old Jul 3, 2008 | 09:05 AM
hotstartup's Avatar
mine wasnt paper. im guessing the carbon one stinks more too! cuz it seems to be oiled
ya dont remove the yellow connector, just do what the diy says.
Old Jul 3, 2008 | 09:38 AM
hotstartup's Avatar
im thinking of sticking a sheet of bounce in this. it still stinks even
Old Jul 3, 2008 | 10:12 AM
ikalinin's Avatar
dude, that is a SICK sig pic!! NIIIIIIIIIIIIIIIIIIIIIIICE!!!
also, to stay on topic, do all MAX's have that filter ? or only the ones w/ auto climate control ?!
Old Jul 3, 2008 | 11:39 AM
jasonmax's Avatar
all ones have that.
Old Jul 3, 2008 | 11:41 AM
jasonmax's Avatar
when you turn off A/C, let it blow fresh air for a while then you'll be good
Old Jul 3, 2008 | 12:44 PM
hi-tek22's Avatar
Wrong
all the 5th gens are "AIR FILTER CAPABLE"
some come with it, and some don't come with it....now as far as the ones that DON'T come with it, IM NOT SURE......I know when i purchased my 01 GLE, it had one
Old Jul 3, 2008 | 01:34 PM
AJ~'s Avatar
AJ~
^ what he said.
I installed the filters in my 2001 easily. Rockauto.com has them cheap (the carbon impregnated ones).
Good advice posted above about running the system on ECON for a short while to dry out the inside of the HVAC system.
Also, Ozium (google it) is excellent at getting rid of the stink.
-AJ
Old Jul 3, 2008 | 01:35 PM
jasonmax's Avatar
Originally Posted by AJ~
^ what he said.
-AJ
yeah, I use it.
Old Jul 3, 2008 | 01:47 PM
Professor's Avatar
opened the one in my 2000 Max, there is a slot, it had no filter, went to the parts store and bought one for like $25 , it has the activated charcoal whatever also to help with odors, no one smokes in the car so thats a big +
Old Jul 3, 2008 | 08:38 PM
maxinthusiest's Avatar
An added benefit is the heating and cooling system will function much better. My AC felt much colder after i did this. Prob cause it was plugged shut. Goodluck
Old Jul 5, 2008 | 10:02 AM
hotstartup's Avatar
really, i felt the opposite
Old Jul 5, 2008 | 04:47 PM
Bjs470's Avatar
I should check mine out.
AaronL
Aug 8, 2020 10:31 AM
uttadms31
Sep 30, 2015 05:24 AM
thenewguyy
Sep 12, 2015 11:12 AM
homeyclaus
Sep 3, 2015 06:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
