Gas Mileage
Old Jul 3, 2008 | 12:58 AM
redrelyt12's Avatar
Gas Mileage
Well I have a 2000 Maxima 5 speed MT. I've been looking around and searching for the speed of the best gas mileage for a long trip. In August I will be driving from Connecticut to Alabama for school and was looking for a final decision on the best speed. I have noticed most people say 62mph with cruise set will have the best result. I do plan on having a tuneup done prior to leaving. I realize that the cost of the tuneup will not save me money but I am looking for the car to complete the trip in as good of condition as possible. I was also wondering if there was anything else I can do to help me spend the least money on gas alone. Thanks.
Old Jul 3, 2008 | 04:36 AM
vball_max's Avatar
The best speed for gas mileage is typically the speed you (or the auto) shift into the highest gear. In my 6-speed, i try to keep the rpm's to right about 2k +/- and that seems to work pretty good. If you have an auto, keep it just above the speed it shifts into the top gear when you are being gentle on the accelerator. The faster you go after that point, the worse the mileage gets....
Also, there are tons of threads about how to get better gas mileage.....search is your friend.
Old Jul 3, 2008 | 08:53 AM
OhOhMax's Avatar
Where ever your car makes peak torque is theoretically where you will get the best gas mileage.
Old Jul 3, 2008 | 09:12 AM
maxdriver10's Avatar
the drag to forward momentum reaches its optimum at 62.5 mph for a 6 cylinder...anything higher than that, and the gain in speed burns to much gas to be economical, especially on long trips
Old Jul 3, 2008 | 09:30 AM
Kyle00's Avatar
WSH for teh cup
this is where you fail
Old Jul 3, 2008 | 11:46 AM
redrelyt12's Avatar
Cruise set in a manual is bad?
I know its not the best in an auto because it down shifts to increase about a half a mile per hour (exaggeration) but how else is cruise control bad?
Old Jul 3, 2008 | 12:00 PM
sunstream453's Avatar
google "hypermiling", consider that cruise control is basically the opposite, and you have your answer
Old Jul 3, 2008 | 05:50 PM
NmexMAX's Avatar
dot dot dot ...
@hypermiling.
Old Jul 3, 2008 | 08:22 PM
maxinthusiest's Avatar
You would gey optimum gas mileage between 60-65
Old Jul 3, 2008 | 09:40 PM
Originally Posted by NmexMAX
@hypermiling.
yeah, i would crack big time either trying to drive like that or driving with somebody that was driving that way
Old Jul 4, 2008 | 12:12 AM
Scottwax's Avatar
That's Mr. Detail to you
I got just under 27 mpg going to Kentucky and back keeping my speeds between 70-78 or so and using cruise control most of the time.
Old Jul 5, 2008 | 03:02 PM
NmexMAX's Avatar
dot dot dot ...
Get some Jack Daniels on that trip?
Old Jul 5, 2008 | 09:24 PM
AEMAXIMA01's Avatar
I just got 31mpg on a trip to the lake and back driving around 60-62. I know it's slow, but it helps. Btw, I have a 5spd 01.
Old Jul 5, 2008 | 09:40 PM
RacerX1320's Avatar
Id say 60mph in 5th NO A.C on. If its completely flat highway then cruise would work as well, but if it has hills id say Cruise off. Keep it at 2k and youll be fine, you can also try a little extra psi in the tires. And by extra i mean like 2 pounds.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
