Rear motor mount replacement
Old Jul 6, 2008 | 07:00 PM
Max_5gen's Avatar
Does anyone have a write up on how to do this? My rear mount makes this funny noise whenever I turn the key to ON and at some other times. The front one made the same noise and I replaced it myself last year but rear one is barely visible from any angle ... My car is 2k auto GLE, has these liquid filled mounts which allow ECU to change their stifness. The easy temporary solution would be to disconnect the socket to the mount but I wonder how difficult is it to fix it right.
Old Jul 6, 2008 | 07:06 PM
pmohr's Avatar
No more Maximas...
Drop the crossmember, replace the mount. Rather easy, especially if you have a lift.
Old Jul 6, 2008 | 09:01 PM
Max_5gen's Avatar
Thanks, I'll give it another look. I don't have a lift, so it is slightly more involved. One question - if I drop the crossmember how far would the engine move down without? I know, there're 2 side mounts as well but I'd like to be sure when I'm under the car.
Old Jul 6, 2008 | 09:06 PM
pmohr's Avatar
No more Maximas...
Not much, really. The two side mounts will hold it up just fine without the center crossmember.
Old Jul 6, 2008 | 09:20 PM
Max_5gen's Avatar
Thank you, looks like I'm going under the next weekend .
Old Jul 8, 2008 | 04:59 AM
Parthur's Avatar
Take pictures and a write up, would be nice.
If I am not asking too much.
Old Jul 8, 2008 | 12:14 PM
adrenaline_rush_fanatic's Avatar
You can get this information from Energy Suspension... they have an install they include with the polyeuthane mounts..
http://www.energysuspension.com/pdf_instruc/17426.PDF
voila... it's not step by step... but there's a simple solution.
Haynes...
Old Jul 15, 2008 | 10:54 PM
Max_5gen's Avatar
Well, I did it over weekend. Unfortunately, I didn't take pictures and I think, I did it in a slightly wrong way. Some of my problems also due to working under jacked up car without using lift. It limits available length of breaking bar. So, here are some notes that might be useful:
1. Start from loosing bolts that connect mounts to crossmember (2 each) and mounts - to engine bracket (1 each) before 'dropping' it: mine were so tight that I had to use 3 pound sledge hummer.
2. Engine mount bolt has square nut which is welded to the engine bracket - there's no need to access passenger side of the bracket to hold the nut.
3. When putting it back together I'd put mounts on the engine first, then connect crossmember to them and the last - crossmember to the car. I swapped last 2 steps and had some troubles placing crossmember bolts through engine mounts.
4. Tighten everything when all the parts are in place and you don't use any extra support for the engine - this way they will be tightened in their normal positions.
5. I used 3.5 hydraulic jack to help me lift the engine a little for crossmember holes to match their mount's counterparts and for overall support.
6. I had to remove airbox to disconnect/connect rear mount socket which is located under the box.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
george__
Aug 18, 2015 07:06 PM
Balkins
Aug 12, 2015 06:39 AM
