BBK Upgrade and the pedal is somewhat soft - Any ideas?
Old Jul 6, 2008 | 09:59 PM
Peanuthead's Avatar
I just upgraded to the 6th gen. calipers, rotors and a set of SS lines. I bleed all of the brakes using the order the manual stated and the pedal still feels a little mushy. It's not rock hard at all. I used Speed Bleeders for the bleeding process so I don't think there is air in the lines at all. Any ideas?
Old Jul 7, 2008 | 08:16 AM
Mizike's Avatar
make sure you put the calipers on the correct side and/or check to see you have both a left and right caliper. I had mine on the incorrect side by not paying attention, which of course did not allow me to bleed the system correctly. There was still air caught in the system after several bleeds.
Old Jul 7, 2008 | 11:40 AM
NmexMAX's Avatar
dot dot dot ...
I vote re-bleed.
Old Jul 7, 2008 | 11:51 AM
Originally Posted by NmexMAX
I vote re-bleed.
Given you changed the calipers...... 99% of the time the brakes need to be re-bled until they're done properly and/or adequately. Simple fix.
Old Jul 7, 2008 | 02:41 PM
Peanuthead's Avatar
I will have to look again. I don't remember the calipers having a side stamped on them but I could be wrong. I'll try the rebleeding again too. It should be rock hard afterwards right? Every other car I have done has been.
Old Jul 8, 2008 | 09:48 AM
LA02MAX's Avatar
The bleed valve has to be on the top. That's how you tell whether it's a right or left caliper.
Old Jul 8, 2008 | 02:23 PM
Peanuthead's Avatar
I must have had a brain fart when I typed that because I knew that. They are on the ride side then. I'll take a look at it again. It can never hurt.
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
2012Maximus
Sep 10, 2015 12:50 AM
Maxboy23
Sep 9, 2015 10:37 AM
slowlifer
Sep 8, 2015 05:53 AM
