How to install cattman headers?
Old Jul 13, 2008 | 07:58 PM
melvinman2003's Avatar
I am about to get a set of cattman headers and have been looking like crazy to find directions. Does anybody have instructions or a link? These are for the 3.5 engine I guess the 5.5 gen.
Thank You
Stephen
Old Jul 13, 2008 | 08:34 PM
Derrick2k2SE's Avatar
There's nothing really complex about it. It's just a lot of work.
Remove anything that gets in the way of removing the manifolds.
After you remove the manifolds, install the headers.
I know that sounds overly simplistic but it's just a nuts and bolts job.
A few tips:
*Remove the fan shroud and fans. (you'll have to remove the radiator hose which will spill some coolant)
*A set of gear wrenches makes the job go much smoother.
*A ratchet with a pivoting head also makes the job easier.
*You may have to unbolt the engine cradle and support it with a jack. This will let give you the ability to move the engine around a little to get to the rear manifold. Don't be afraid. It's not that big of a deal.
If you have a specific question you can PM me with your #.
I've done the install twice.
Old Jul 14, 2008 | 07:10 AM
MDeezy's Avatar
He makes a good point
It sounds like a straight forward job but you'll see how complex it can get. Front should be fairly painless once the fans are out of the way. Swivel head is a must. The rears is where the fun comes in. Once you get the intake manifold off, it will make for more space, it will still be hard to see into there so you'll probably end up using touch as your sight.
Old Jul 14, 2008 | 03:44 PM
Ok awesome. Thats exactly what I needed to know. I was pondering if I should have a shop do it but ive done all my mods thus far so might as well bang this out on a weekend. Thank you for your help
Stephen
Old Jul 15, 2008 | 06:03 AM
NmexMAX's Avatar
dot dot dot ...
http://www.cardomain.com/ride/687468/6
http://forums.maxima.org/5th-generat...-56k-dare.html
Old Jul 15, 2008 | 10:40 AM
Czerkas's Avatar
http://www.hotshot.com/instructions/NS3017.html
i think this is for hotshot headers but it should be the same ..
good luck, i will be attempting this by the end of the month, and with my lack of tools, i am not looking forward to it ..
Old Jul 15, 2008 | 10:41 AM
NmexMAX's Avatar
dot dot dot ...
Going through the bottom is definitely easier, but also harder to do 'at home' w/o lift / proper jacks, etc.
MaxLife17
Jun 27, 2019 01:37 PM
Maxboy23
Sep 4, 2015 06:04 PM
Samedi
Sep 3, 2015 01:07 PM
Johnny9595
Sep 3, 2015 05:18 AM
