Just Got My H&R Springs!!!
Old Nov 6, 2001 | 05:11 AM
PCGuRu2K's Avatar
This must be one of the best handeling mods out there. After I got it installed as soon as I saw a sharp curve I took it right away at full throttle =) Car didn't sway or move a bit. I noticed that my car doesn't bounce as much any more when I hit a slope in the road. It's a little more stiffer now. I kinda like that better though.. Does the ride get better or worse over time? I did keep my stock shocks on my GLE...
Old Nov 6, 2001 | 05:23 AM
FloMax's Avatar
Re: Just Got My H&R Springs!!!
Your stock shocks will be fine for a month or two, then look out, they start heading downhill pretty fast. I still have the stock shocks on my SE with Eibachs, and it is a rough ride if I have anyone in the back seat. I would certainly recommend that you upgrade your shocks at some point in the not too distant future. But enjoy the springs, they do make a significant difference!
out.
Old Nov 8, 2001 | 09:18 PM
Raf2kMax's Avatar
Did you install it yourself?? around how long did it take and how easy is it for someone who knows what theyre doing but doesnt have a lot of shop experience? thanx
Old Nov 8, 2001 | 10:45 PM
punkdork's Avatar
Eibachs are a lot stiffer than H&Rs... I've been in a 5th gen with both. Your stock shocks should be good for a while.
As far as install time. It depends on your tools. The first time I did my springs it took nearly a full day... we had a lunch break, used all hand tools, had to hit the store for a new tool.. twice, etc. Second time (shocks) I was down to four hours with one less helper.
I should add its the first time I'd ever done springs on a car
Old Nov 9, 2001 | 11:16 AM
MichaelAE's Avatar
Somebody probably already asked you this, but what made you move to the Eibachs from H&R? Most of these similar threads have made me lean towards Tokiko's with H&R's...just curious.
Old Nov 9, 2001 | 01:19 PM
punkdork's Avatar
Oh.. I never had H&Rs... Timwumax had them. My car has eibachs.. hence, I've been in both.
H&Rs are good for mainly lowering. Eibachs better for performance. I went for the lowering direction.
As far as tokicos go, I bought kevs when he went to the coilovers.
Lemme know if you wanna see what the ride is like, we could always meet up and I could drive your car again
Old Nov 9, 2001 | 02:13 PM
MichaelAE's Avatar
punkdork
I'll take you up on that offer when I get to springs and shocks. New wheels and tires are my next change after I get my a$$ around to putting the RSB, which is sitting in my living room, on.
Old Nov 9, 2001 | 02:40 PM
Greg's2kGLE's Avatar
In your sig it says you have Eibachs...but above you said you went towards the lowering direction --->H&Rs
Old Nov 9, 2001 | 02:57 PM
punkdork's Avatar
Sorry sometimes I hit the crack pipe a little too hard. I meant I went in the handling direction. I have eibachs. Maybe if I post pictures people will no for sure I'm not just high still.
Old Nov 9, 2001 | 02:58 PM
punkdork's Avatar
punkdork
Lemme know if you want a hand with any of that. I've been itching to turn a wrench and haven't had extra money for mods... new tires sucked up my y-pipe fund
Old Nov 9, 2001 | 06:23 PM
BigDogJonx's Avatar
Well I did the install for all 4 springs in 3hrs. I could have done it in 2hrs if it was not for the 1hr of chilling with hand tools. If I had a air impact wrench, I would have saved alot of time on the compression of the spring compressors.
But still 3hrs aint bad.
Old Nov 9, 2001 | 07:15 PM
2maxguy's Avatar
After reassembling the front struts do you think you need a wheel alignment?
Old Nov 9, 2001 | 09:35 PM
How much were your Maxspeed Springs? How big of a drop are they? How is the ride?
Old Nov 10, 2001 | 06:47 AM
UMD_MaxSE's Avatar
Got Bent?
yes, you should get an alignment after installing the springs...
Old Nov 10, 2001 | 10:05 AM
BigDogJonx's Avatar
Got my springs off a guy on eBay, bought them for $95. The drop in the front was approx 1.75" the back about 1.4"
Old Nov 10, 2001 | 12:07 PM
Do you have any before/after pictures? Does the drop even out the wheel gap front and rear? How is the ride?
Old Nov 10, 2001 | 12:17 PM
2001SE's Avatar
Can someone please explain to me what's:
Shock?
Coliver?
Strut?
Spring?
and why after you put the H&R's you'll struts will get more stiff after a short period of time
Old Nov 10, 2001 | 01:27 PM
BigDogJonx's Avatar
Here is the before pic
Here is the after pic
The ride is fine, almost like stock. Drop is very even both front and back.
Dixit
Old Nov 10, 2001 | 01:31 PM
BigDogJonx's Avatar
Shock?
Coliver?
Strut?
Spring?
Shock is a straight up shock that is separate from the springs. It is normally on american cars and some foriegn cars.
Coilover is a strut/spring combination that can be adjusted in height by turning the top plate.
Strut is same thing as a shock but it is where the "shock" goes in the middle of the spring. And on top of that a strut hold the springs in place.
Springs are the things that give the car the ability to bounce so that your whole car dont feel the bump.
Old Nov 10, 2001 | 01:34 PM
Dixit
Wow those get rid of a lot of that wheel gap. For $95, I might consider those in the future.
Old Nov 10, 2001 | 03:56 PM
RBa's Avatar
RBa
I think progress are lower... Those are 17in rims?.. You definately lose all wheel gap with progress. It's alittle bit more money though...
Old Nov 10, 2001 | 03:59 PM
Progress springs drop lik 1.7" right?
Old Nov 10, 2001 | 04:16 PM
RBa's Avatar
RBa
Yep.. Toylet has them but he has the stock 16s.. Still, almost no wheelgap.. I think he paid like a buck... And the ride is pretty close to stock.. It might also be b/c of the tokicos..
Old Nov 10, 2001 | 04:36 PM
A buck?!?!
Old Nov 10, 2001 | 04:43 PM
RBa's Avatar
RBa
A buck?!?!
I meant a hundred bucks...... Not $1
Old Nov 10, 2001 | 04:54 PM
cobymoby's Avatar
Max speed? I thought you had H&R's?
Old Nov 10, 2001 | 06:35 PM
BigDogJonx's Avatar
No I believe the Progress and these are about the same. I do recall Keving telling me that they were the same or the Maxspeed had a slight edge.
The guy who sold them to me said they dropped from 1.7" to 1.9"
Dixit
Old Nov 11, 2001 | 12:38 AM
ItalianMax2kSE's Avatar
Dixit
What is the guy's e-mail? Those are very nice and I want them!
Joe
Old Nov 11, 2001 | 07:43 AM
Cisco's Avatar
Still did not get those B&G's eh?
GC
Joe
Old Nov 11, 2001 | 08:56 AM
RussMaxManiac
Yes, once you replace the springs you need a alignment...
Old Nov 11, 2001 | 08:57 AM
[QUOTE]Originally posted by Cisco
[B]Still did not get those B&G's eh?
GC
Paul @ avaoln told me that they are STILL on back order. I ordered um in August! He said they are just now getting some B&G springs in but none for the Max yet, but they should be in soon, but I payed over $200 for um, so I might cancel um and get the Max Speed springs. I like um cause BigJohn says they are like a stock ride and because of the different drop in the front and back, I want it level. Why did Nissan make it lopsided anyway!
-Joe
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
