Crankshift Positioning Sensor - Recall
Old Jul 17, 2008 | 05:01 PM
nismomaxx's Avatar
I recently had my clutch changed, after the clutch swap my car threw a Service Engine Soon light, I have a OBD2 reader and the codes were Camshaft Positioning Actuator Banks 1 & 2.
After doing some research, that partciular piece is under recall... Mine never got replaced, therefore I'm going to get my swapped. Figured I'd post it up, and let everyone know.
http://www.internetautoguide.com/aut...ima/index.html
Pulled directly from that website :
Recall Summary
ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
Consequence
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Old Jul 17, 2008 | 07:45 PM
Scottwax's Avatar
That's Mr. Detail to you
If the work has never been done, the dealership shouldn't give you any problems about performing the work. In my case, the work had been done, so I had to pony up for the bank 1 sensor.
Old Jul 18, 2008 | 06:37 AM
'02_EMILBUS's Avatar
So never had a warranty when I bought the car.. and I get this code. The dealer should fix it with no questions asked, regardless (given it hasn't been done before)???
Old Jul 18, 2008 | 06:50 AM
soundmike's Avatar
Very sound, Mike
A recall will apply to any owner, regardless of warranty status.
If you guys have the problem, i suggest having it replaced immediately. When i had the issue the SES light took its sweet time showing up. So for the longest time i had been experiencing the complete loss of power while on the road and nobody could fix it.
It's a hair-raising experience when you're on the freeway when suddenly you lose power in the middle lane with everyone zooming past you. Or worse, you take off from a stoplight, engine dies, you sit there with hazards on and trying to start the car back up, with a big rig (along with the rest of moving traffic) heading your way from the back at 40mph honking like crazy.
Old Jul 18, 2008 | 07:24 AM
Scottwax's Avatar
I agree with soundmike, get it fixed. My car wouldn't completely die, but for a second or two, there would be no power then my car would start running normally again. It would do it once or twice, then not again for months. My code reader would show a pending P0340 code (if I remember right) which was the bank 1 sensor, but the SES light would never actually come on.
Old Jul 18, 2008 | 09:51 AM
CMax03's Avatar
Does yours fall in the VIN range in accordance with the RECALL! The Stealership isn't obligated to fix all three sensors only the one/s that are defective. My cam Sensor on Bank 1 went out that's the rear bank with cylinder 1,3,5. I asked for all of them to be replaced and they only did the cam sensor @ bank one! I didn't fall in the VIN range either....
Old Jul 18, 2008 | 10:27 AM
phatboislim's Avatar
is this for the 5.5 gen?
Old Jul 18, 2008 | 10:39 AM
NisMoN00B's Avatar
+Cru OG
I had my CPS recall done for free on my 5.5. I just mentioned it to the service manager, two hours later, I picked up my car.
Old Jul 18, 2008 | 01:21 PM
Czerkas's Avatar
I went in for a bad blower motor and they told me about this, free work .. i figured why the hell not...
Old Jul 19, 2008 | 06:43 AM
nismomaxx's Avatar
I'm so pissed, went to Lia Nissan in Enfield, CT. Service manager did a Serivce-Comm on my VIN, told me that it doesn't need to be replaced yet my car is throwing codes for it... Where do I go from here?
Old Jul 19, 2008 | 05:45 PM
CMax03's Avatar
do it yourself it's easy! cost is about $75 but call ABC Nissan 18003731066 or hook up with DaveQ! Have autozone clear it if you don't have a OBD2 tool.... the rear head is where the sensor is on the transmission side!
Old Jul 19, 2008 | 09:21 PM
nismomaxx's Avatar
I have a OBD2 Reader, I clear the code and it comes back in 10 minutes.
Old Jul 19, 2008 | 11:30 PM
CMax03's Avatar
Change the part then clear it and it won't come back! The part is held in by 1 bolt......how can you fix the problem without removing it ( the faulty part)?
Old Jul 21, 2008 | 07:07 PM
phatmax95's Avatar
I just had mine done for free on the recall. Threw the code on the way home, went by Advance and got it checked. Next day drove to the dealership and it tried to cut out on me, then when I arrived and shut off the car, it wouldn't start.
Long story short, get it done as it can leave you immobilized. Mine went from a-ok to a no-start condition within 30 miles.
Old Jul 21, 2008 | 08:17 PM
nismomaxx's Avatar
I know man, it did that to me in the middle of an intersection... I'm very upset with the fact I cannnot get it replaced on the recall... I called Nissan of North America, the gentleman named Mark Allen told me that the only thing I could do was pay the $94.00 to get a Licensed Nissan Dealer to run their diagnostics on the vehicle and go from there. I asked if he could tell me what was the next step and he said that the only tihng Nissan could do was replace it out of "Good Will" which was very unpromising....
gavin68
Sep 18, 2021 12:36 PM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
soybeanz
Sep 25, 2015 10:46 AM
