foggy headlights.... water leak?
Old Jul 22, 2008 | 01:01 PM
d4ster3's Avatar
last summer I posted on here regarding clearing out my headlights... I completed the task (removing headlights, place in oven, replace orange blinker lens with a clear one, etc.) and now my headlights are really foggy, especially after washing it.. Ive tried wet sanding the headlight and applying plastX but I think its foggy bc water is leaking in from where I took the headlight apart and didnt seal it back together good enough... ANYWAYS, what should I do? I was thinking about taking the headlights apart again (using the oven method) drying them out good and applying plastX to both sides... thoughts???
Old Jul 22, 2008 | 01:03 PM
phatboislim's Avatar
yea i recommend taking it apart and resealing em.
Old Jul 22, 2008 | 02:22 PM
scarface4522's Avatar
i had a little condensation getting into my driver side headlight, all i did was dry it out with a hairdryer and resealed the top and i havent had a problem since.
Old Jul 22, 2008 | 04:20 PM
irish44j's Avatar
retired moderator
take out the turn signal bulb so airflow can get in there, that will get rid of the moisture (assuming it's not humid or rainy). Run some clear silicone around entire housing where it meets the lens and smooth with your finger.
Old Apr 3, 2009 | 11:19 AM
80mixam's Avatar
Please point me to link or thread where steps for headlight removal, drying and sealing of headlghts (2003 Maxima) is discussed. I have foggy headlights that I had tried cleaning - without removing them - by using 600, 800, 1000, 1500 and 2000 grit sandpaper (wet) and Novus plastic polish. It made fog even worse. Maybe I did not hand buff and polish enough (a few minutes per grit and polish x 3 levels). Maybe the 600 or 800 scratched things up. Thank you very much if reply comes.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
