NGK Laser Iridium plugs
Old Jul 29, 2008 | 10:06 AM
sampimpinthug's Avatar
I have a maxima 00', and I am doing the regular tune up for my car and I was wondering if it is a good idea to get the NGK laser iridium plug part #7944. Are they too extreme for my max or should they be fine?
Old Jul 29, 2008 | 10:08 AM
IHAVEA2KMAXIMA's Avatar
I think that would be okay. I use laser platinum myself.
Old Jul 29, 2008 | 10:12 AM
no SES light yet? Because I have heard a few stories about air intakes, that people install aftermarket airintakes and their MAF sensor goes crazy.
EDIT: What difference do you notice with laser platinum?
Old Jul 29, 2008 | 10:16 AM
NmexMAX's Avatar
dot dot dot ...
Laser Pt is stock, so probably nothing.
My bad I meant Laser Iridium. Sorry!
Old Jul 29, 2008 | 10:19 AM
NmexMAX's Avatar
dot dot dot ...
Strange PN you got there. Any more info on this plug?
Old Jul 29, 2008 | 10:22 AM
again my bad it is 7994.
Old Jul 29, 2008 | 10:26 AM
NmexMAX's Avatar
dot dot dot ...
I was expecting something along these lines :
PFR5G-11
mtrai760's Avatar
'Trynna' is not a word
That is an NGK stock#, not a part#. That would be the OE Laser Iridium IFR5E11.
I would save my money and just get the NGK platinums, but that is just me.
Old Jul 29, 2008 | 10:30 AM
If I get the laser iridium would it drop my rpms? Because the sole reason I might buy them is because I want my car to feel like it is not started when I am stopped.
Old Jul 29, 2008 | 10:33 AM
NmexMAX's Avatar
dot dot dot ...
It wont drop your idle RPM's but it has been said to idle smoother. I noticed that with my current plugs (Iridium). But, it could have been a number items, most namely, they were well over due for a change.
Also, to add to what mtrai stated, it is not worth it to pay that much more for a smoother idle.
Old Jul 29, 2008 | 10:35 AM
mtrai760's Avatar
Your idle RPM is controlled by your ECU, not by your spark plugs. At idle in neutral with no accessories on and fully warmed up it should be solid at 750 RPM.
Old Jul 29, 2008 | 10:37 AM
what are the possible things which could make my idle smoother? I know distributor cap is one of the things? any others?
Old Jul 29, 2008 | 10:38 AM
in Neutral it is solid at 750 and feels like the car is not started but when I put it in drive it is not as smooth.
Old Jul 29, 2008 | 10:49 AM
mtrai760's Avatar
Worn motor and transmission mounts are a commom culprit.
Old Jul 29, 2008 | 11:07 AM
I guess there is nothing much i could do about that.
Old Jul 29, 2008 | 11:11 AM
mtrai760's Avatar
You could replace them, but it is going to be pretty expensive for new ones.
Old Jul 29, 2008 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
The price for the actual mounts are not bad, it is labor involved that can get costly/time consuming.
And we do not have distributors here.
Old Jul 29, 2008 | 01:34 PM
damerbullet's Avatar
Grounding Kit (made by Shinduho I think?) made a lot of difference in my RPM.
Old Jul 29, 2008 | 01:56 PM
Scottwax's Avatar
That's Mr. Detail to you
Iridium plugs will last longer than platinum, supposed to potentially go 200k between changes.
Iridiums did make a difference in my 626 but the plugs in it were getting old so hard to say how much of the improvement was the actual plug material and not just that I replaced old plugs.
Old Jul 29, 2008 | 02:08 PM
NmexMAX's Avatar
dot dot dot ...
That sounds so familiar.
Old Jul 29, 2008 | 02:47 PM
BARBARIUS MAXIMUS's Avatar
i have never had a set of plugs last as long as 200K
Old Jul 31, 2008 | 10:12 AM
maxima 5th gen doesn't have distributor? I heard few newer cars come distributorless, didn't know maxima did.
Old Jul 31, 2008 | 10:48 AM
sergey85's Avatar
how about those pulse plugs im not doing(expensive)but was wondering if anyone had experience with them.
Old Jul 31, 2008 | 11:29 AM
mtrai760's Avatar
4th gen+ has no distributor.
Old Jul 31, 2008 | 01:47 PM
Scottwax's Avatar
I got your back on this one. Just making sure it isn't just one person saying it.
Old Jul 31, 2008 | 01:50 PM
Scottwax's Avatar
Pretty expensive plug to have to pull the intake (5.5 gen) and replace every 50k miles.
Old Jul 31, 2008 | 02:10 PM
NmexMAX's Avatar
dot dot dot ...
Yup, always helps, there’s power in numbers (quantity)
Old Jul 31, 2008 | 04:57 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
replacing the NGK platinum ones with the Iridiums ones... will let everybody if I feel somethnig different. As for the price they were the same 9.99 each.. Autozone.. Orlando Florida.
Old Jul 31, 2008 | 10:42 PM
CMax03's Avatar
I've been running those iridium plugs as well, one step cooler since I do alot of highway driving and going to the strip now and then.
Old Aug 1, 2008 | 06:59 AM
NmexMAX's Avatar
dot dot dot ...
I run 1 step colder on my rear bank only .
Old Aug 1, 2008 | 07:34 AM
Scottwax's Avatar
NGK Iridiums were $6.99 each when I bought them for my old 626 about 18 months ago.
Old Aug 1, 2008 | 07:38 AM
NmexMAX's Avatar
dot dot dot ...
Invalid apples to oranges comparison. Even from 01-02 the PN is different.
Old Aug 1, 2008 | 07:55 AM
mtrai760's Avatar
Since I only do about 1/2 my driving on the highway, does that mean I should stagger and run every other plug cold?
Old Aug 1, 2008 | 07:57 AM
NmexMAX's Avatar
dot dot dot ...
Do 1 bank only...
Old Aug 2, 2008 | 12:04 PM
so what is the verdict? should I go ahead with those iridium or not? I have 133 miles on my car right now.
Old Aug 2, 2008 | 12:05 PM
what is a grounding kit? should I get it?
BTW I only got my car recently in april and it had 132 miles on it.
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
