Rattling Noise During Acceleration
Old Jul 30, 2008 | 01:44 PM
NJYTHRD's Avatar
2003 SE Maxima
There has been a Thread or two on here before about this. I couldn’t find it, so if anyone could direct me to it I would appreciate it….. Or just start it over again.
As many of you have had this problem…. There is a rattling noise coming from the engine compartment towards the rear of the motor, underneath the motor during acceleration at low speeds and highway speeds. Just a slight touch of the gas pedal will cause this. Sounds like a heat shield or something lose to make this noise.
As the dealership says, "Just use higher Octane Gas and that should stop the problem," because after hooking up to there computer there are no error codes.
Thanks All
Old Jul 30, 2008 | 02:17 PM
sublime258's Avatar
Sounds to me like it could be a rear motor mount, based on your description.
Oh and by the way...for your sig:
is'nt = isn't
Old Jul 30, 2008 | 02:33 PM
mmg23max's Avatar
do you hear the noise also when you put the car in gear
Old Jul 30, 2008 | 02:35 PM
NmexMAX's Avatar
dot dot dot ...
Check your heat shields.
Old Jul 30, 2008 | 02:36 PM
NJYTHRD's Avatar
No, its just during acceleration. Not pressing on the accelerator hard.
Old Jul 30, 2008 | 02:51 PM
mmg23max's Avatar
oh ok,jack the car up and support it with a jack stand and take a look at the rear mount
Old Jul 30, 2008 | 03:16 PM
SoonerFan's Avatar
Cletus
check the oil level
Old Jul 30, 2008 | 03:53 PM
skidz88's Avatar
Pretty sure it's pinging.
Old Jul 30, 2008 | 05:35 PM
NJYTHRD's Avatar
skidz88 said it right. I used the wrong word - (rattling) It's a pinging noise.
Old Jul 30, 2008 | 07:06 PM
skidz88's Avatar
For some reason your car is running lean and causing the engine to knock. Some say to try one step colder plugs, or change fuel filter, or that you could have an air leak somewhere.
Old Jul 31, 2008 | 06:24 AM
papasuede's Avatar
I had the same problem and I cleaned the MAF and it went away.
Old Jul 31, 2008 | 02:42 PM
DaBoxSE's Avatar
Could possibly be the rear pre-cat going bad.
Old Jul 31, 2008 | 08:37 PM
irish44j's Avatar
retired moderator
common causes of this kind of noise:
1. engine knocking/pinging - run a tank of super unleaded and see if it goes away
2. precats or main cat going bad - not all that common
3. heat shield on precats or cat loose, rusted, and/or contacting frame/body/exhaust. This is EXTREMELY common on 5th gens. Start here.
Old Jul 31, 2008 | 09:29 PM
hi-tek22's Avatar
do you have a sound clip
i know my car was rattling on startup and the moment i put it in drive, it would get slightly louder and then go away as the car continued to warm up and the RPM's dropped..........oh well it ended up being a heat shield
Old Aug 1, 2008 | 09:16 AM
NJYTHRD's Avatar
Thanks everybody. This gives me a little ammo to toss at my mech to have him look at a couple of these things.
Old Aug 1, 2008 | 09:34 AM
321VQ35MAX's Avatar
My 03 6Mt had that problem and the Nissan dealer replaced 1 of my cat converters.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
