Engine Tired ?
Old Aug 3, 2008 | 04:32 PM
Professor's Avatar
Engine Tired ?
Lately the car seems to not have any get up and go anymore, it dont like pulling hills more then 40 mph.......no codes, new plugs , new filters, fresh tranny flush, everything seems fine, no dragging brakes, I always use Shell Premium fuel, it just seems to be lazy anymore.
Any Ideas?
Old Aug 3, 2008 | 04:38 PM
nalc's Avatar
check fuel pump and filter maybe?
carsarecool's Avatar
How many miles do you have? mine seemed to do that sometimes when it hit 90k
Old Aug 3, 2008 | 04:41 PM
Professor's Avatar
129k so far
Old Aug 3, 2008 | 04:47 PM
Professor's Avatar
I would replace the filter but its built into the fuel pump and it seems no one around where i live have a hint of knowledge where i can locate one, i tried to get ahold of DaveB with no luck.
Old Aug 3, 2008 | 04:53 PM
Gemini67's Avatar
New battery?
Old Aug 3, 2008 | 05:18 PM
johnnyd2k2's Avatar
Here is a how to on fuel filter replacement on a 5.5 gen
http://www.innerbean.com/housecor/fuel_filter.html
Old Aug 3, 2008 | 05:21 PM
Professor's Avatar
Mines a 5th gen but iam sure its similar
Old Aug 3, 2008 | 05:22 PM
Professor's Avatar
Originally Posted by Gemini67
New battery?
Brand new optima about 3 weeks old.
Old Aug 3, 2008 | 06:09 PM
sascuderi's Avatar
How old is the MAF in your car? As the MAF "dies", the car will feel sluggish and won't always give a code.
Old Aug 3, 2008 | 06:44 PM
Professor's Avatar
I believe its oem from the day it was new.
Old Aug 3, 2008 | 07:06 PM
Merlyn's Avatar
And... I'm out
I would try dave B again, I talk to him at least once a week... yes he is busy but I still am able to talk to him at times *shrugs*
Old Aug 3, 2008 | 07:22 PM
+1 on the MAF i've actually heard that more than a few times on this site
Old Aug 4, 2008 | 05:33 AM
mist max2000's Avatar
id bet money on a MAF ill say im 95% sure.. get a green dot MAF..(make sure its not white)
Old Aug 4, 2008 | 05:38 AM
phatboislim's Avatar
bet its the catalytic convertor..have u redone ur exhaust system or anything to it?
mine was sluggish when i purchased it, figured it was something minor..i was fortunate that the cat blew and i didnt blow my engine instead
Old Aug 4, 2008 | 06:43 AM
papasuede's Avatar
Had the same sluggish problem on the hills, at the start when cold, ticking/pinging of the engine, and the engine racing at 3200-3800 RPMs. I changed the MAF and it all went away. Car pulls like it did the day I drove it off the lot.
Old Aug 4, 2008 | 08:32 AM
dansmax2003's Avatar
Just to make it easy on your pocket ... go to your Auto parts store and get a CRC MAF Cleaner spray.
Pull out the MAF sensor, spray it nicely (i used half a bottle), let it dry for 10-15 minutes, put it back in and see if it feels any better.
The MAF cleaner costs less than $10. Your car has 100K+ miles on it, so it won't hurt to try this.
I did it on my '03. Car seemed to run "fine" but since i have close to 120k miles & original MAF, i decided to spend the $7 for the MAF cleaner. After i cleaned the MAF - wow! my car does run better. It is much more responsive and accelerates just like it did the day i got it. I got 1-2 MPG extra too ... consistent over the last 5-6 weeks. Not bad!
Give it a try...
P.S. >> If you're running the original fuel filter, i agree with everyone here that you must replace it. I did it when my car had 80k miles and the filter was very very dirty. Not super hard to do. You have to pull fuel pump out of the tank, relieve some of the pressure before disconnecting, but other than that...it's not such a scary job, as long as you pay attention to the details.
Old Aug 4, 2008 | 08:40 AM
kzoosho's Avatar
ks maybe?
Old Aug 4, 2008 | 02:20 PM
Professor's Avatar
No exhaust work, all factory
Professor's Avatar
Give it a try...
Did that already, no diff except no more lean codes.
Old Aug 4, 2008 | 02:21 PM
Professor's Avatar
Originally Posted by kzoosho
ks maybe?
Doubt its the knock sensor, but who knows, them things are pricy.
Old Aug 4, 2008 | 05:10 PM
sascuderi's Avatar
What year is your max and how many miles?
Old Aug 4, 2008 | 08:34 PM
ITS THE MAF /THREAD..
spend the 100 bucks you wont regret it i promise you..
Old Aug 4, 2008 | 10:08 PM
dewd's Avatar
and by "its the MAF/Thread" you mean the actual sensor cabling piece that clips on? or some type of switch box/tube (help me out im a newbie srsly)
Old Aug 4, 2008 | 10:18 PM
wyche89's Avatar
they should have a little cartoon character for MAF
come on, we should all know this by now.. this type of problem will automatically get the official maxima.org default solution for all performance related problems... MAF
Old Aug 4, 2008 | 10:19 PM
wyche89's Avatar
he means it's the MAF and that should be the end of this thread
"/" basically means end of
Old Aug 5, 2008 | 05:55 AM
if its not the maf...try the cat then
Old Aug 5, 2008 | 08:24 AM
CMax03's Avatar
Have you checked your fuel pressure yet?
Old Aug 5, 2008 | 01:34 PM
Professor's Avatar
No, I havent, but today i noticed it surges sometimes and when it surges it feels like i got a ton of power all the sudden, the tires squeal even if i lightly press the gas to pull out and then it dont, iam not sure whats going on, but now it seems to have random bouts of no power then ***** to the wall power.
Old Aug 5, 2008 | 01:41 PM
o...my cat never gave power til it blew out
Old Aug 5, 2008 | 01:44 PM
Professor's Avatar
MAF MAN
YOU HAVE ANGERED THE MAF!
Old Aug 5, 2008 | 01:56 PM
jasonmax's Avatar
I sometimes feel that way, maybe our maximas are a little bit weather sensitive?
Old Aug 5, 2008 | 02:10 PM
LOL @ MAF PIC
Old Aug 5, 2008 | 02:33 PM
jasonmax's Avatar
try this
http://forums.maxima.org/5th-generat...10-w-pics.html
Old Aug 5, 2008 | 04:29 PM
Professor's Avatar
Originally Posted by jasonmax
Umm....... there is a post already about this, i dont need to do this since ive done it 3 times already with no difference.
Old Aug 5, 2008 | 04:30 PM
Professor's Avatar
I agree, in the morning when its cooler and at night it seems more up and go but this is in the middle of the day.
Old Aug 6, 2008 | 06:36 AM
NmexMAX's Avatar
dot dot dot ...
Lean codes typically mean MAF.
Old Aug 6, 2008 | 08:13 AM
CMax03's Avatar
We're not running with carburators here...That's the duty of the MAF to adjust to difference in air quality/quanity/altitude/density/humidity! So therefore weather is not a factor or shouldn't be....
Old Aug 6, 2008 | 08:28 AM
classic..lol.. (/thread) = end thread= thats the answer to the OP's question.. many other experienced ppl ,nmexmax and wyche have stated this as well to be the leading cause...and this problem and solution has been beaten more then a red headed step child on here..look around search MAF.. to help to newb- the maf-mass air flow sensor is plugged in sensor in line with your intake in the black tube..100$ 00-01(green dot), triple that for 02-03,.. although there is a way to make an 01 fit an 02/03.. hope this helped g/l.. and FYI there is a newbie thread where people are very helpful .. find it
Old Aug 6, 2008 | 08:30 AM
well whatever it is...my max is sensitive to weather too
