OBD Problem
Old Aug 12, 2008 | 10:22 AM
blackandwhite's Avatar
To them I'm like an idol
OBD Problem
My car is not giving any reading when the OBD monitor is hooked to it.
The check engine light is on, but no power is going to the OBD connector so that it can be read.
Is there a fuse or something for this?
Old Aug 12, 2008 | 11:03 AM
mtrai760's Avatar
'Trynna' is not a word
Time to download the FSM. There is a wiring diagram that shows how everything is routed to the OBD connector. Forget the page#, but I was just looking at it a few days ago.
Old Aug 12, 2008 | 01:35 PM
jkayca's Avatar
Hmmm...I seem to remember you need to have the ignition in the on position but the car not started.
Old Aug 12, 2008 | 03:04 PM
I got that part...still not working
Old Aug 14, 2008 | 09:25 PM
PadawanKnight's Avatar
Make sure all the pins are good on the scan tool. I was having an issue of no power going to mine and realized that 2 pins were bent and I wasn't getting a good connection.
Old Aug 14, 2008 | 10:24 PM
Drockb418's Avatar
does your car start?
Old Aug 23, 2008 | 07:36 AM
ptspringer's Avatar
make sure the connection is good. the OBD meter should indicate if it is connected.
Old Aug 25, 2008 | 10:18 AM
Yeah it starts.
Both autozone, and an emissions inspection place have not been able to read it though.
Old Aug 28, 2008 | 08:29 PM
02_Maxima_6sd's Avatar
A friend of mine had the same problem when he used an autozone scanner. we tried my scangauge tool and it would not read the code. His car would not start though so you can probably eliminate the ecm being the culprit. he was not so lucky.
Old Aug 31, 2008 | 07:05 PM
leescotty2001's Avatar
Yea that is tru what 02 Maxima 6sp said...
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
