is it normal to have metal shaving on the magnets on the tranny oil pan
Old Aug 18, 2008 | 02:02 PM
imported_D_Roc's Avatar
me and my dad changed the tyranny fluid on my 01 max and i found some metal shaving on the magnets on the oil pan is it normal the last change was done 60k ago but we didn't change the strainer just changed the fluid is it ok
thnaks
D
Old Aug 18, 2008 | 02:15 PM
Froggmann's Avatar
If it's a LOT then no if there is a moderate ammount then your fine.
Old Aug 18, 2008 | 02:16 PM
Love_00_Max's Avatar
Ideally there is metallic grime on the magnets. Visible metal shavings is not a good sign, either way doing the flush was the right step.
Really sucks to have magnets inside the pan vs the drain bolt. One has to bring the pan down to get to know if there is something happening in the tranny (dropping the pan often is a N0-NO since there are so many bolts and the aluminum block is so soft risking cross threading).
Old Aug 18, 2008 | 02:22 PM
Scottwax's Avatar
That's Mr. Detail to you
That's what I was going to say!
Clutch packs do wear, that is one of the reasons you flush the old coolant out.
sublime258's Avatar
I just did a tranny flush on my '02 for the first time a few days ago with Amsoil ATF. The magnets were coated with a lot of metallic sludge, but I couldn't visibly see any actual metal shavings...
Old Aug 18, 2008 | 04:09 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it is normal wear of the tranny.
Old Aug 18, 2008 | 05:51 PM
AceofSpds's Avatar
wat
You have get the pan off to change the filter though.
Old Aug 18, 2008 | 09:46 PM
CMax03's Avatar
That's normal to have a metallic paste as long as there are no metal flakes (plating), no large metal splinters longer than 5/16"(gear edges) you'll be ok...It normal wear and tear.
Old Aug 18, 2008 | 11:25 PM
foodmanry's Avatar
Da Roller Coaster!
Yes, but its not really a fillter, but just a screen (ok a screen filter). You really shouldn't have anything in the screen filter. It is meant for metal rather large metal shavings. If you have large metal shavings then you have problems.
I have over 160K on my my and clean the filter screen only one time. It has been fine.
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
dcam0326
Sep 18, 2015 04:52 PM
rbaker100
Sep 6, 2015 02:46 PM
