HIDs in 2k2 Fogs???
Old Nov 7, 2001 | 08:53 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
HIDs in 2k2 Fogs???
Ok i'm looking to to and match all the bulbs on the front of my car, highs, running lights and fogs. I was gonna get some PIAA's for 60 bucks or so but i said, hey just get the HIDs, how do you think they will look if i get an OSRAM kit from 97GLES?? Also any other suggestions for other bulbs for the front???
Old Nov 7, 2001 | 10:23 PM
BigDogJonx's Avatar
Re: HIDs in 2k2 Fogs???
It can work, but I think HOGAN posted just earlier how to install HIDs in your fogs. But I do recall that the HIDs have to be H4s. I think the 97GLE came with H4s.
But read HOGANS writeup, it is right HERE
Dixit
Old Nov 7, 2001 | 10:32 PM
emax02's Avatar
4th gen's have H3's in the fog lights. I think the same goes for a 2002 max, I could be wrong though. Steve, I put 9006 size HID's in my I30's foglights{Sylvania}. I had to bore out a big area to get the bulbs to actually fit, then I just glued them on with some 5 minute eppoxy/super glue. I think you saw my Hid setup at one of the meets.
Old Nov 7, 2001 | 10:48 PM
radpp16's Avatar
Re: Re: HIDs in 2k2 Fogs???
Dixit
Dam i saw those HIDs i person,,, the PANASONIC headlights and the h3 fog HIDS. Hogan really drives around like its daylight 24/7.
Man when i get money to blow on h4 hids to use as h3 hids i will. kinda costly.
Roger
Old Nov 7, 2001 | 11:36 PM
NJ_MAX2000's Avatar
For the guys installing the HID's (not the OEM 2k2's) on the 5th Gen.'s, are you guys just disabling the flashing of the high beams from the alarm? Do you have to go through the same procedure as the install of the 2k2 OEM's to disable the flashing? Or is it a modified procedure?
Old Nov 7, 2001 | 11:41 PM
BigDogJonx's Avatar
Well if you have a 2K1, you need to go to the same procedure I came up with to fix the alarm flashing problem. I dont know how the fix works on a 2K cause the wiring changed slightly.
Dixit
Old Nov 8, 2001 | 04:36 AM
so basically there is no direct fit HID yet for the fog light. I guess i'll get some PIAA Super Plasma H3's and wait, i'm not hacking up my 2k2 for HIDS, although i really want them
Old Nov 8, 2001 | 06:02 AM
Sonic's Avatar
Frankencar II
And Steve starts with the ghetto modding...
TallTom
57
Oct 14, 2025 05:16 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
