how do i erase the abs light?
Old Aug 23, 2008 | 10:23 AM
imported_D_Roc's Avatar
i searched and found one but it was linked to another thread which is no longer available so how do i do it on a 2001 maxima
thanks
D
Old Aug 23, 2008 | 11:29 AM
gotendbz1's Avatar
thanks
D
you get your abs fixed, then light will go away.
Old Aug 23, 2008 | 01:12 PM
pmohr's Avatar
No more Maximas...
The procedure to check and clear ABS codes is in the FSM, BR-48 and BR-49.
Old Aug 23, 2008 | 01:16 PM
thanks man
Old Aug 23, 2008 | 01:26 PM
another quick question is the "data link connector" and the OBD 2 port the same thing if not where is it, and what does it mean "disconnect the check terminal from ground" its to the procedure to erase the light on the fsm BR-49
thanks
D
Old Aug 23, 2008 | 01:29 PM
pmohr's Avatar
No more Maximas...
thanks
D
The DLC (Data Link Connector) is the OBD-II port.
The grounding part is assuming that you checked the codes prior (BR-48), if you didn't don't worry about it.
Old Aug 23, 2008 | 04:11 PM
no the grounding part is to erase the code and fsm says
HOW TO ERASE SELF-DIAGNOSTIC RESULTS
(MALFUNCTION CODES)
NFBR0108S04
1. Disconnect the check terminal from ground (ABS warning lamp
will stay lit).
2. Within 12.5 seconds, ground the check terminal 3 times. Each
terminal ground must last more than 1 second. The ABS warning
lamp goes out after the erase operation has been completed.
3. Perform self-diagnosis again. Refer to BR-48. Only the start
code should appear, no malfunction codes.
what does part 1 mean which connector is it? and where is it located ? this is on br 49
thanks
D
Old Aug 23, 2008 | 04:14 PM
pmohr's Avatar
No more Maximas...
thanks
D
That's what I'm talking about, it's assuming that you checked the codes immediately prior to clearing them. Don't worry about it.
Old Aug 23, 2008 | 06:14 PM
hi-tek22's Avatar
couldnt have said it better my self
Old Aug 23, 2008 | 07:25 PM
Dr. Roy's Avatar
+1
the fact that the light is on means something is broke/malfunctioning. the ABS system does a diagnostic every time you turn the car on.
-every thing in working order = no light
find out whats broken and fix it, the light will take care of itself
Old Aug 23, 2008 | 07:44 PM
KRRZ350's Avatar
Technically it runs the diagnostic every time you go over (?4?) mph in reverse.
Old Aug 23, 2008 | 08:02 PM
pmohr's Avatar
No more Maximas...
Only once, and forward gears too
Old Aug 24, 2008 | 12:37 PM
hollywood's Avatar
ABS light came on for a 2003 maxima SE 6speed, turned out to be the back wheel speed sensor. I hope this information helps.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
maximusrising
Sep 2, 2015 09:55 AM
