replaced rear calipers...
Old Aug 25, 2008 | 04:56 PM
MAXIMA_STYLE's Avatar
Ok so i replaced my rear calipers but im kind of concerned, before i drive the car i know i need to bleed the brakes, but my concern is why can i not spin my rotors ? Will they free up once the calipers are bled?
Old Aug 25, 2008 | 05:07 PM
n3985's Avatar
大陆弟弟
Did you push the piston all the way back? to be flush with the actual caliper? You drove to NYC and back without bleeding your brakes? O_O
Old Aug 25, 2008 | 05:08 PM
ITS as far back as i could get it, if it is sticking out an 1/8 inch, would that affect it? And will that go away after bleeding?
Old Aug 25, 2008 | 05:09 PM
n3985's Avatar
大陆弟弟
Was the "cross" on the piston correctly oriented? As in the + mark on the actual piston
Old Aug 25, 2008 | 05:10 PM
I CANT RECALL....DOES IT MAKE A DIFFERENCE WHETHER THE NOTCHES ARE IN A PLUS PATTERN OR NOT?
Old Aug 25, 2008 | 05:12 PM
n3985's Avatar
大陆弟弟
Why are you you yelling? Trying to help you out here...
In your last thread I gave you the link for the DIY, whose pictures clearly show the steps and yes the notches do matter.
http://forums.maxima.org/5th-generat...-question.html
Old Aug 25, 2008 | 05:16 PM
sorry im not yellin LOL i was doin something else also, i cant find what i was looking for, so what happens if they are fully installed and the notches arent in the + sign symbol?
Old Aug 25, 2008 | 05:19 PM
n3985's Avatar
大陆弟弟
Originally Posted by I30/I35 FAQ
Another important note on this step is when you’re done ratcheting the piston, make sure that the piston head has its holes in a "cross" or “plus” meaning holes are on top, bottom, left and right. See picture below. Look what happens at the next picture if it’s not, that brake pad notch will cause the piston to push the brake pad unevenly. You’d probably screw up the brake pad and piston for sure.
That should help
Old Aug 25, 2008 | 05:21 PM
ok so your basically saying i need to take both sides apart again and make sure i get the + or cross symbol ....why does it need to be shaped like that? are there cntacts points or something that need to be correct?
Old Aug 25, 2008 | 07:14 PM
vinco's Avatar
yep, the brake pad has a nub on it that has to line up with one of the holes/notches/low spots in the +.
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
maxipower
Aug 21, 2015 11:10 AM
