Intermittent Alt warn light
I am working on now with a 2k2 maxima (50kmiles).
Durin last few mths it has had intermittently Alt lamp on - ONLY ALTERNATOR warning lamp. This condition may go off after shutting and restarting engine.
Also few times the MIL check lamp has been flashing for a short period, gone out while driving - NOTE: NO error code was found stored in ECU. This vehicle has been twice at nissan stealership, no help from there
...(yes they would swap new alt with 2500$)
At least once overcharge voltage has been detected at 15.6Volts...
At least this 2002 Maxima seems to have the Brake/Alt warn light connection via a diode. This should mean that no charge causes both lamps to illuminate?
My questions: What should happen
a. when no charge
b. overvoltage (regulator semi dead)
c. rectifier diode problem (Alt pushing AC current).
d. Is my suspicion right (?) that the voltage regulator inside alt is dying causing intermittent AC and/or VERY high charge voltages.
e. Will replace the alt soon, reman 300$ alt is already in the trunk = will this correct this intermittent alt warn lamp issue?
f. Are there any other known problem spots?
Confuzean FSM logic: Contradicting schemas can be found at 2k2 FSM page EL-120,136,139. (At page 120 the alt lamp is connected to MIL lamp via a diode - instead of the mentioned BRAKE warn lamp...)
Hi Quality (?!): My 3gen alt regulator died also at 80k ... that story depicted here: http://www.cardomain.com/ride/748507/23
...(yes they would swap new alt with 2500$)At least once overcharge voltage has been detected at 15.6Volts...
a. when no charge
a. when no charge
a. when no charge
Agree. Have had the same problem on other cars. Too bad car companies don't have external voltage regulators (like my Chevelle did), so easy to replace instead of the whole alternator.
Probably why they made the change, eh?
Yes cheap multimeters can show anything, (at least on low battery), learned that the hard way. However, my multimeter no.6 was displaying 14.1V (idle) just prior Nissan Consulttesting at stealership (also 14.1V, idle)...
The battery (replaced 2yrs ago) isnt totally dry. Points to overvoltage.
I'll replace the alt and later open the original, tell what was found. My guess is that it needs just rectifier cleanup like my 3gen alt ... see the pic how brushes wear out and spread conducting dirt all around. My 1. theory is intermittent short circuit across this sludge, 2nd is a dying regulator (because of this?):
Now tell me WASSUP: test-disconnecting alt charge wire, causes ONLY alt led to come ON at idle. Revving, the lamp shuts OFF after 1500 rpm! ...and all seems to be ok...
Seems like the Alt lamp is living its own life (computer ctrl?) regardless of charge voltage. If so, the FSM schema is bs...
(Note that when the lamp had earlier been on, it had been steady on until shutting engine. Its not std brush wear out/stick problem which normally causes alt warn to blink...)
Tech swap question: Will soon swap the alt anyways. I guess (?) the radiator has to be taken out first as FSM suggests?
. May be just loosing it will give you enough room.
U bet this is not my first alt problem... First one on 2k2 maxima, and THE first one, where no charge warning lamp depends on rpm (charge supply wire disconnected) ... idle ON, revving OFF. I fear that I'll find Intel Inside with semi installed Vista...
I do agree that a short circuit would be seen on that diode dust. As u said, it may cause small .15A batt drain which was my 3gen alt problem.
Seems that taking out rad fan assy is enough to pull alt out... figuring out on the hidden alt bolt. Worst case ever, cant see, cant reach... plus manual pics below Chilton comic book -level.
Update; at least two problems found so far:
The alt 2-pin connector did not come out in one piece. One of the pins [S] was heavily oxidized. When installing the new alt, the broken connector and pins were loose: like this, the pins have never made good contact... I bent the pins in the new alt until the connector press in -insertion felt tight (30 degrees with pliers), added contact grease. Then locked the connector with a tiewrap... (Tomorrow new bearing for the tightener pulley, pics will follow some day after opening the used alt)
The 'original' alt had no NISSAN -logo. So it cant be original?
Btw. No need to take radiator or fans out. Best way is to drop the AC compressor and then drop the alt. The compressor has to be taken out anyways to reach the long alt bolt.
The problem in the first place was that this alt connector did not come out in one piece
folks, it wont in your neither). Also you cant see or reach it well enough. One is supposed to push in the alt connector lock clip and then pull, but the lock pin wont release. (Thus I guess I bought unnecessarily that spare alt.)Third problem is grounding: there is no exxtra GND-wire from the alt shroud. It is a known universal problem that the bolts/shroud lose contact to the engine, and alt GND will eventually become floating = semi connected to engine-GND. 3gen max has that from factory ... I have to add now here.
The tightener pulley bearing was also bad, next have to swap it. (as said, llater I will make a writeup with pics).
I added another to make sure in my 3gen, like this:
HowTo Ground http://www.cardomain.com/ride/748507/10
Update:
Heres the alt oxidation [S]-pin pic. The whole alt swap writeup is at bottom of page... http://www.cardomain.com/ride/748507/23
Update:
Has your overvoltage problem gone for good?
As new alt has all voltage regulating bits inside it, this same problem should not return. Now all wet with contact grease
The only thing I didnt like was the 120A charge fuse at battery terminal - I could not get it out (tried to force it out) and still suspect whats inside there?Sorry to say folks, but I wont swap my 3gen until a 6gen drops by - u see independent suspension, lacking pwr, etc...
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
