Keyfob "Unlock" Trigger
Old Sep 1, 2008 | 11:59 AM
zero2sixtyZ's Avatar
You embarrass me.
I read the Door Handle LED install in the 6th gen forums a while ago, and it looks so nice. However, in the thread (http://forums.maxima.org/6th-generat...d-install.html), the LEDs are wired to the door/courtesy lights which apparently light up once the "unlock" button is pressed. On the 5th gens, this does not happen. The door lights turn on when the door is opened. How can we wire something up to trigger when the "unlock" button is pressed?
Old Sep 1, 2008 | 12:03 PM
scarface4522's Avatar
i dont have an answer to your question but that does look hot on the 6th gen, it would be great if someone can figure out a way for us 5th gens to do it
n3985's Avatar
大陆弟弟
Lots of members have tried to do something similar. The only wire which can be used for this is the dome light wire, but that has been found to be ground triggered. Good luck and let us know if you find a method.
Old Sep 1, 2008 | 07:38 PM
Pri63's Avatar
I've had this setup on my car for about two years now and had to run the wiring, ground and positive to the dome. Works like a charm, unlock the door handles light up, lock them and they turn off.
I'll up a vid as soon as possible.
UPDATE: LINK:http://video.google.com/videoplay?do...02207788&hl=en
Old Sep 1, 2008 | 07:49 PM
Norkoastal's Avatar
Nice. Any other angles of the kit? I also like the mirror you have setup up. Signals and flashers linked?
Old Sep 1, 2008 | 07:56 PM
n3985's Avatar
大陆弟弟
DIY on the wiring please!
Old Sep 2, 2008 | 06:31 AM
You embarrass me.
Please chime in a DIY for the wiring on the dome light end! Did you run wires to each B-pillar then go to each door? Headliner had to be removed, correct?
Old Sep 2, 2008 | 08:56 AM
n3985's Avatar
大陆弟弟
So you literally just ran separate power and ground wires straight to the dome light? Did you take off the roof liner or something?
Old Sep 9, 2008 | 11:52 AM
n3985's Avatar
大陆弟弟
Pri63, how did you run new wiring direct to the dome? Are the original wires to the dome tucked in the driver A-pillar and you tapped it there or did you remove the roof liner to run the wiring? Thanks
Old Sep 9, 2008 | 06:36 PM
Pri63's Avatar
Sorry for the delay...work is owning me.
To answer the question...I wired both the ground and positive leads of the wire up to the dome light because when I tried grounding elsewhere, I didn't get the desired "light on unlock" effect. The dome ground is actually what makes the lights go on and off on the unlock trigger.
Getting the wiring up to the dome without having to remove the roofliner was kind of a pain. I took something a little less rigid than a hanger to snake up the roof liner. I then tied the wires to it and snaked it back through. I thought that was the hardest part...I was wrong. Getting the door handles off and drilling and epoxying a 3mm LED in the handle was a pain.
Old Sep 10, 2008 | 02:59 AM
PhalC1's Avatar
So where does the dome light wire go? It has to connect somewhere in or around the dash. Maybe I'll be the guinea pig and find out?
Old Sep 10, 2008 | 05:12 AM
burnurass's Avatar
to add to this, I wired up my puddle lights for my cefiro power folding mirrors up the bpillar and around the sunroof to the dome light. YOU can pry it a little and tuck the wire in. Not bad at all. I then split the signal after the bpillar under the dash rather than run the wires twice from the dome light.
Old Sep 10, 2008 | 08:04 AM
dineth00i30's Avatar
to n3985 and norkoastal doesnt our infiniti's light up when we unlock the car?( i donno how it is when we open with the remote bcus i dont have a remote but when i unlock with my keys the dome lights turn on)
Old Sep 10, 2008 | 08:16 AM
n3985's Avatar
大陆弟弟
Yes, the dome light turns on. Which is exactly why some of us want to tap that signal source to for other items like puddle lights, door handle LEDs...etc so they too come on when we unlock.
Old Jan 19, 2009 | 04:17 AM
cwfalconfootbal's Avatar
Buyers beware, local pick up recommended. Slow to ship out items already paid for.
the only problem I think might happen if you wire it to the dome light is that when you turn on the dome light from inside the car wouldnt the lights in the handles turn on?
Old Jan 24, 2010 | 08:33 PM
a33_ridah's Avatar
any ideas if the outsid handles will light with the domelight on from the inside with doors closed??
Old Sep 6, 2010 | 08:15 AM
HomerMAC's Avatar
Donating i30 Owner
If im not mistaken it will if you tapped the +/- from the dome light bulb. I think your supposed to tap the line that comes from the door trigger.
Old Sep 6, 2010 | 08:49 AM
You embarrass me.
Tap into the wire from the A-Pillar. Search jowo9 for his LED Door Handle DIY.
Old Sep 6, 2010 | 09:59 AM
another idea...used this for my puddle lights on my side mirrors...the ring around the ignition that lights up. positive and negative.
jc53
Oct 12, 2015 05:12 AM
Sep 27, 2015 08:37 AM
Pixel
Sep 15, 2015 05:53 AM
Slamrod
Sep 3, 2015 07:38 PM
crazyespn
Sep 3, 2015 01:30 PM
